Visonic Powerlink RS232 Hack
Moderators: Rene, Willem4ever
Re: Visonic Powerlink RS232 Hack
Postby Digit » Tue Aug 09, 2011 4:54 pm
I wrote some extra code for myself to make it all a bit more human readable, now all those bytes get a meaning :)
<0D A5 00 02 BD 06 00 00 00 00 00 00 43 51 0A
Keep Alive, Open Zones: 1 3 4 5 6 8 10 11
<0D A5 00 04 00 20 01 03 00 00 2C 00 43 C2 0A
Status: Disarm, Flags : Zone event, , Zone 01 Open
<0D A5 00 02 BC 06 00 00 00 00 00 00 43 52 0A
Keep Alive, Open Zones: 3 4 5 6 8 10 11
<0D A5 00 04 00 20 01 04 00 00 2C 00 43 C1 0A
Status: Disarm, Flags : Zone event, , Zone 01 Closed
<0D A5 00 02 AC 06 00 00 00 00 00 00 43 62 0A
Keep Alive, Open Zones: 3 4 6 8 10 11
<0D A5 00 04 00 20 05 04 00 00 2C 00 43 BD 0A
Status: Disarm, Flags : Zone event, , Zone 05 Closed
<0D A5 00 04 00 20 05 03 00 00 2C 00 43 BE 0A
Status: Disarm, Flags : Zone event, , Zone 05 Open
Postby Digit » Tue Aug 09, 2011 7:05 pm
Here's a the traffic I saw while I Armed my PowerMax.
I saw messages not mentioned before here, starting with A7
(the times displayed are minutes and seconds)
00:17 > :0D A1 00 00 04 <pin> <pin> 00 00 00 00 00 43 <cs> 0A
00:17 < 0D 02 43 BA 0A
00:17 < 0D A5 00 01 00 00 00 00 00 00 00 00 43 16 0A
00:17 < 0D A5 00 04 01 40 00 00 00 00 2C 00 43 A5 0A
00:18 < 0D A5 00 04 01 00 00 00 00 00 2C 00 43 E5 0A
00:18   Status: Exit Delay Flags :
01:07 < 0D A5 00 04 01 10 00 00 00 00 2C 00 43 D5 0A
01:07   Status: Exit Delay Flags : Last 10sec. delay,
01:16 < 0D A5 00 04 04 48 00 00 00 00 2C 00 43 9A 0A
01:16   Status: Armed Home Flags : Bypass On, (dis)Arm or Alarm event,
01:16 < 0D A7 01 00 2B 51 00 00 00 00 2C 00 43 6B 0A
01:17 < 0D A7 01 00 2B 59 00 00 00 00 2C 00 43 63 0A
01:17 < 0D A7 01 00 0B 5C 00 00 00 00 2C 00 43 80 0A
01:17 < 0D A5 00 04 04 08 00 00 00 00 2C 00 43 DA 0A
01:18   Status: Armed Home Flags : Bypass On,
01:18 < 0D A7 01 00 08 5C 00 00 00 00 2C 00 43 83 0A
01:18 < 0D A7 01 00 06 5C 00 00 00 00 2C 00 43 85 0A
01:18 < 0D A7 01 00 05 5C 00 00 00 00 2C 00 43 86 0A
01:18 < 0D A7 01 00 03 5C 00 00 00 00 2C 00 43 88 0A
Postby Rene » Tue Aug 09, 2011 7:08 pm
Those messages indicate a status change of the panel and are already described partly, see viewtopic.php?f=68&t=6581
Armed Home
Forced Arm
Bypass, could 0x0B be zone 11?
Bypass, could 0x08 be zone 8?
Bypass, could 0x06 be zone 6?
Bypass, could 0x05 be zone 5?
Bypass, could 0x03 be zone 3?
Postby Digit » Tue Aug 09, 2011 7:23 pm
Hmmm, must have been much too late last night :)
And I didn't recheck again today...
Zones are right, those were open last night :)
Zone 6 is questionable..
Postby Odin » Thu Aug 11, 2011 12:44 pm
OK my RS232 interface kit has arrived. My panel is a Complete panel and I don't have the option of 'activating' powerlink (it seems to know it is there without activation!) so will have to somehow trigger it.
Odin
Postby Bwired » Thu Aug 11, 2011 2:11 pm
follow the flow in the first post
on my powermax plus i did not need to activate it with a powerlink
Postby Odin » Thu Aug 11, 2011 2:29 pm
thanks you Bwired - I will give it a try (sorry for this - I am new to serial stuff)
Do you use Putty or some other software tool to 'talk' to the powermax via RS232?
Odin
Postby Willem4ever » Fri Aug 12, 2011 7:43 am
Odin wrote:Do you use Putty or some other software tool to 'talk' to the powermax via RS232?
Most of us wrote their own little tool in python/C or VB ...
Willem4ever
Postby Odin » Fri Aug 12, 2011 9:21 am
OK last night I was fiddling around in Perl as I have this on my NSLU2
Odin
Postby Willem4ever » Fri Aug 12, 2011 11:36 am
perl runs on a pc well ....
Willem4ever
Postby Odin » Fri Aug 12, 2011 1:29 pm
Willem4ever wrote:perl runs on a pc well ....
indeed it does run well. However I thought I'd run this on my NSLU2 as it only consumes 5W of power and is a full linux server where I have my email server/php/apache/mysql etc.
Odin
Postby Odin » Fri Aug 12, 2011 6:03 pm
and my code is started..
here is a trace from my perl job when pressing the 'arm home' button on the keyfob for a Powermax complete panel
[Fri Aug 12 17:57:45 2011] - Received From Alarm Subsystem: 0da5000100000000000000004316
[Fri Aug 12 17:57:45 2011] - Received From Alarm Subsystem: 0da50004014100000002000043ce
[Fri Aug 12 17:57:45 2011] - Received From Alarm Subsystem: 0da500070000000000030000430d
[Fri Aug 12 17:57:45 2011] - Received From Alarm Subsystem: 0da5000b0000000000000000430c
[Fri Aug 12 17:57:45 2011] - Received From Alarm Subsystem: 0da5000c0000000000000000430b
[Fri Aug 12 17:57:46 2011] - Received From Alarm Subsystem: 0da5000d000000000000000043
and then pressing the disarm button:
[Fri Aug 12 17:57:48 2011] - Received From Alarm Subsystem: 0da50004004100000002000043cf
Odin
Postby Odin » Wed Aug 24, 2011 9:46 pm
Hi - does anyone know of a way of getting the info on which keyfob armed/disarmed the alarm when activated/deactivated?
When I press the arm home button, I get the following but there is no keyfob info on that:
0da50004014100000006000043ca
Odin
Postby Willem4ever » Thu Aug 25, 2011 7:22 am
See message 0xA7 ....
Willem4ever
Postby Odin » Thu Aug 25, 2011 9:26 am
Willem4ever wrote:See message 0xA7 ....
Thanks - however I don't get an A7 message from my panel - only A5 and A2 msgs.
I am logging in with 0DAB0A00010000000000000043060A - is this correct?
Odin
PreviousNext
