Opentherm Gateway memoryleak problem
Postby ITHJ » Wed Dec 28, 2016 9:55 am
I'm using the Opentherm Monitor software version 4.3.0.2. on a Windows 10 Machine for 1 year now.
After the program has been running for a few weeks I noticed that the memory allocation is constantly growing at a small increments.
Ultimately the application crashes with a message that "Wish" cannot allocate xxx bytes of memory.
Does anyone recognize this behaviour, and is this a known issue?
For a next release it could be an option to have an automatic restart per day or week?
Of course if there are memory leaks it could also be solved by looking at the source of the problem.
Kind regards, ITHJ
ITHJ
Re: Opentherm Gateway memoryleak problem
Postby hvxl » Sat Dec 31, 2016 4:15 pm
Please create an html directory next to your otmonitor executable if it doesn't yet exist. Unzip the attached file in there. If necessary, enable the web server.
After otmonitor has been running for at least 2 hours, direct your browser to http://<ip>:<port>/variables.html and save the output. Then after a few days/weeks when the memory use has increased noticeably, visit the page again. If there are any significant changes, that may point to the problem area.
variables.zip
(828 Bytes) Downloaded 122 times
cron
