Newbie Question MSG 129-130
Postby umtauscher » Sun Feb 26, 2017 3:20 pm
Hi everyone,
This is my first post to this forum and I wanted to thank Schelte for his incredible work making this gateway as great as it is.
I was very impressed how detailed the documentation is and managed instantly ordering the needed components.
Over the past few days I was building the gateway and it seems to work as expected. I used a Raspberry Pi 3 to run the OTMonitor program and to get the gateway connected to my netwwork.
I am monitoring the behaviour of my equipment for a day now via the web interface of the OTMonitor.
I have a Brötje WGB 2N Boiler and the Brötje RRG which seems to be a Siemens QAA73.
Since I see several Messages in the log that don't get interpreted, (MSG 128, 129, 130), do I have to make a special configuration to the gateway to get them accepted/transferred or is this just normal?
Thanks for any help
Wilhelm
umtauscher
Re: Newbie Question MSG 129-130
Postby Templar » Mon Feb 27, 2017 1:04 am
umtauscher wrote:Since I see several Messages in the log that don't get interpreted, (MSG 128, 129, 130), do I have to make a special configuration to the gateway to get them accepted/transferred or is this just normal?
Paragraph 5.1 Overview from the Opentherm Communications Protocol - Protocol Specificatioon states:
Id’s 0 .. 127 are reserved for OpenTherm pre-defined information, while id’s from 128 .. 255 can be used by manufacturers (members of the association) for test & diagnostic purposes only.
Those id's are specific for the Siemens QAA73 thermostat and unknown.
Templar
Postby umtauscher » Mon Feb 27, 2017 10:11 am
Thanks, yes, I read that and I umderstand it.
I was just wondering, if I have to do something, that OTGW accepts or transmits theese Messages to the other side or if its just transparent for unknown messages.
umtauscher
Postby Templar » Mon Feb 27, 2017 8:40 pm
The OTGW transmits those ID's to the other side unless the gateway was instructed otherwise http://otgw.tclcode.com/firmware.html#configuration
For example:
UI=Data-ID
    Unknown ID - Inform the gateway that the boiler doesn't support the specified Data-ID, even if the boiler doesn't indicate that by returning an Unknown-DataId response. Using this command allows the gateway to send an alternative Data-ID to the boiler instead.
    Examples: UI=18, UI=6
OTmonitor doesn't know these new ID's and doesn't know the data type. You can find out and alter OTmonitor (otmonitor.tcl file) an add a few lines code after line 1960. (I don't know if that does the trick, I am not a developer):
register 90   {u8 nu}      "Size of fault buffer V/H"
register 91   {u8 u8}      "Fault buffer entry V/H"
register 107   {u8 u8}      "Size of fault buffer solar storage"
register 108   {u8 u8}      "Fault buffer entry solar storage"
# Class 8: Control of Special Applications
register 7   {f8.8}      "Cooling control signal"
register 9   {f8.8}      "Remote override room setpoint"
register 14   {f8.8}      "Maximum relative modulation level"
register 15   {u8 u8}      "Boiler capacity and modulation limits"
register 100   {nu flag8}   "Remote override function"
Templar
