How to check if OTGW properly assembled?
Postby Bororo » Wed Jun 21, 2017 2:23 pm
Dear Friends,
is there any guideline what to check/measure on currently built OTGW?
I have no access to the boiler for the moment, so I can't connect OTGW in between boiler and thermostat, but I would like to know if OTGW is working as it should.
All I can do is to power OTGW with 220V.
Many thanks in advance.
Bororo
Bororo
Re: How to check if OTGW properly assembled?
Postby fabian » Sat Jun 24, 2017 11:54 pm
Bororo wrote:is there any guideline what to check/measure on currently built OTGW?
hvxl explained this in detail on http://otgw.tclcode.com/debugging.html
fabian
Postby Bororo » Sun Jun 25, 2017 8:00 am
Hi Fabian,
thank you for mentioning this guide.
For me it's not clear if part Opentherm Interfaces measurements/checks are done with OTGW connected to boiler and thermostat, but I will check at least parts related to 220V (Power supply).
Thank you for your help.
Bororo
Postby D_Hailsham » Sun Jun 25, 2017 10:06 am
Bororo wrote:For me it's not clear if part Opentherm Interfaces measurements/checks are done with OTGW connected to boiler and thermostat
The first line says:
If you have built the Opentherm Gateway and it doesn't work, or you are the cautious type and prefer to check the device step by step before hooking everything up
I take this to mean that the checks are done without the boiler or thermostat connected - unless you are told to connect them, e.g in Slave Interface it says:
connect your Opentherm thermostat to X1 and in Master Interface it says: Connect the Opentherm signal from the boiler to X2
D_Hailsham
Postby marcelr » Sun Jun 25, 2017 10:06 am
That's a matter of careful reading. From the first sentence in the troubleshooting manual:
If you have built the Opentherm Gateway and it doesn't work, or you are the cautious type and prefer to check the device step by step before hooking everything up, here are ...
Postby marcelr » Sun Jun 25, 2017 10:07 am
@D_Hailsham: you beat me by a fraction of a second. Congratulations!
Postby D_Hailsham » Sun Jun 25, 2017 12:00 pm
As we say in England: RTFM! :lol:
D_Hailsham
