remeha calenta not sending information
Postby labium » Sun Jul 08, 2018 3:30 pm
i bought a nodo shop otg with wifi . it oconnects well to the otmonitor program. i connected my calenta remeha boiler to the gateway but no info shows up in the otmonitor program i have no thermostat connected yet. am i doing something wrong. the boiler is connected tot the boiler plug of the otg and in the boiler connected to the plug where normally the thermostat is in (on -off)
labium
Re: remeha calenta not sending information
Postby hvxl » Mon Jul 09, 2018 10:56 pm
Normally you should get some output from the OTGW. How did you configure the NodeMCU and OTmonitor? Is there a flashing LED on the OTGW? Do you get any response on a PR=A command?
Postby labium » Wed Jul 11, 2018 6:25 pm
o do get respons from the otg but the otg doesnt get any response from the boiler
labium
Postby Cooter » Wed Aug 29, 2018 8:15 pm
It can not be connected to the on off contact.
Only connect to opentherm contacts.
Cooter
