No DHW preheating after a power failure
Postby grubciu69 » Wed Feb 06, 2019 9:31 am
I have Vitodens 100 (boiler 230V power supply) and iSense AD 289 (thermostat powered from OTG) and between them is OTG (battery power supply). Everything works well but after the 230V voltage recovery, after a voltage failure when the boiler does not work, the boiler does not heat up the domestic hot water to the set temperature, the rest is working correctly. After disconnecting and reconnecting the thermostat, everything returns to normal. Can this problem be solved by issuing a command in the OpenTherm Monitor application?
grubciu69
Re: No DHW preheating after a power failure
Postby hvxl » Tue Feb 19, 2019 8:49 pm
It is difficult to make suggestions without understanding what causes the behavior you describe. So please provide a log that covers the whole scenario.
