IC2 MAX232 pins in OTGW schematic
rickvanderzwet
Post by rickvanderzwet »
At the schematic page IC2 (MAX232) seems to missing pin 15 (Vcc) and 16 (GND), which are shown in the assembly sheet.
Also the marking V+ and V- is slightly confusing (i confused V+ for Vcc). V+ is marked VS+ and V- is marked VS- in the MAX232 datasheet.
Re: IC2 MAX232 pins in OTGW schematic
The schematic was drawn using the eagle software package by Cadsoft. This software comes with many libraries of devices. The MAX232 chip available in one of those libraries is drawn like that; without actually showing the Vcc and GND connections. While it is possible to add your own library of devices, it is quite a bit of work. So I just used the existing device.
rickvanderzwet
The linked Conrad component datasheet uses the MAX232 by Texas Instruments, maybe use their Eaglesoft version of the library created by Vitaly Luban from Conexant, which could be found here?
