Toon suddenly stopped measuring gas
Forum about Toon hardware, both versions 1 and 2 of Toon
Re: Toon suddenly stopped measuring gas
Postby mogwai » Sat Nov 30, 2019 2:12 pm
Seems that I have the same problem. Logging stopped 2019-11-25 23:12:37 on both Toon and Domotics, both connected to the same P1 port. So the only explanation is that the port stopped working.
How did you get it fixed? Just call the "netbeheerder"?
mogwai
Postby Smiggel » Sat Nov 30, 2019 2:15 pm
mogwai wrote:Seems that I have the same problem. Logging stopped 2019-11-25 23:12:37 on both Toon and Domotics, both connected to the same P1 port. So the only explanation is that the port stopped working.
Correct. I my case they did a check to see if they could read data from the gas meter. They were not able to do it and noted there was a malfunction. So they came by to replace the gas- and electricity meter. Now everything works again.
Smiggel
Previous
Return to Toon Hardware
