Toon Recovery
Forum about Toon hardware, both versions 1 and 2 of Toon
Re: Toon Recovery
Post by TheHogNL »
You just need to connect the serial after this point: "INFO:recovery:Toon booting into recovery shell. For now, just start your favourite serial terminal
Don't reboot/hit reset because that will put your toon back into normal mode again :)
As the ToonRecovery also connects using serial (on the jtag wires) you can just open a serial interface on the Pi on serial port /dev/serial0
PeJeWe
Re: Toon Recovery
Post by PeJeWe »
i got the menu working and recovered it partially.
it can boot.
i have a backup of my VPN config but it is no longer in my toon.
were can i put the files
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
Re: Toon Recovery
Post by TheHogNL »
PeJeWe wrote:i got the menu working and recovered it partially.
it can boot.
Didn't you use the backup and recover VPN config option of the recovery tool?
You just need to place the backup back to the /etc/openvpn directory
PeJeWe
Re: Toon Recovery
Post by PeJeWe »
it can boot.
I accidentally deleted some files.
i have now not my original eneco toon name it is now: eneco-001-000000
Re: Toon Recovery
Post by TheHogNL »
PeJeWe wrote:
it can boot.
That is the name it gets from the recovery. And when you restore the vpn config it will restore the hostname also.
But I still don't understand exactly why you didn't use the vpn backup option in the recovery tool?
Do you have a valid vpn backup?
PeJeWe
Re: Toon Recovery
Post by PeJeWe »
The recovery program didn't found the VPN data because the files were not there anymore.
Because I had accidentally removed some files. (stupid me)
I had the VPN config files earlier backed up when I bought the the toon and rooted it.
Therefore the recovery program could not fix the VPN config problem.
The toon is now working fine because of the recovery program. :D
Only the name of my Toon is wrong. :|
Can I change the name afterwards?
TerrorSource
Re: Toon Recovery
Post by TerrorSource »
You can change the name in /etc/hosts* files.
PeJeWe
Re: Toon Recovery
Post by PeJeWe »
TerrorSource wrote:You can change the name in /etc/hosts* files.
Thanks to you're guys :D my Toon is up and running.
I only have to restore my ical number of the afvalwijzer app.
Re: Toon Recovery
Post by TheHogNL »
PeJeWe wrote:The recovery program didn't found the VPN data because the files were not there anymore.
You where smart to backup your openvpn config during rooting :-)
Chefkeds
Re: Toon Recovery
Post by Chefkeds »
Thanks for this TSC tool! It revived my rooted toon.
I had to read this tread how to connect toon serial.
('sudo apt install screen' and 'screen /dev/ttyS0 115200')
toontoon2
Re: Toon Recovery
Post by toontoon2 »
Ik probeerde vandaag mijn toon te herstellen na een crash.
Hiervoor heb ik de toonrecovery tool gebruikt om een om bestandsysteem te formatten en opnieuw te installeren.
Dit loste het probleem van niet opstarten op, echter heb ik nu geen mogelijkheid meer om updates te installeren.
Dit lijkt dus te komen doordat ik (DOM!) vergeten ben een backup te maken van mijn vpn.
Gelukkig heb ik nog een oude toon met een kapotte display waarvan ik de oVPN gegevens van zou kunnen recyclen.
Hoe kan ik de bestanden op de oude toon naar de nieuwe toon overzetten zodat deze weer netjes gaat updaten?
De oude toon heeft een defecte moederbord (beeld is links verschoven), dus moederbord swap werkt niet.
toontoon2
Re: Toon Recovery
Post by toontoon2 »
nevermind heb het gefixed.
Wellicht ter referentie voor anderen met zelfde probleem:
1) Root je oude toon en gebruik WinSCP om de hele etc/OPENVPN map te kopieren naar je harde schijf. Kopieer ook het bestand etc/hosts
2) Root je nieuwe toon (gebruik optie -f, want je gaat niet kunnen updaten omdat VPN niet werkt) en gebruik daarna WinSCP om de contents van de gekopieerde OPENVPN map te kopieren naar je nieuwe toon.
3) Kijk in het bestand etc/hosts die je hebt gekopieerd naar je harde schijf om te zien wat de naam is van je oude toon (eneco-001-xxxxx). Open vervolgens het bestand etc/hosts op je nieuwe toon en zoek naar eneco-001-0000 of iets vergelijkbaars. Vervang deze naam met de naam van je oude toon.
Reboot je toon, en probeer nu te updaten met het scriptje, Als het goed is nu je VPN wel online en kan je updaten.
Success!
En maak niet mijn fout door te snel alles te willen doen en maak altijd een backup indien er de optie voor is :-)
Ik had gelukkig nog een dode toon liggen in een doos, anders was het weer een tripje naar marktplaats....
Re: Toon Recovery
Post by TheHogNL »
toontoon2 wrote:nevermind heb het gefixed.
Success!
Euh,.. de toonrecovery maakt een backup van je VPN key voordat hij gaat formatteren .. heb je die optie misschien overgeslagen?
toontoon2
Re: Toon Recovery
Post by toontoon2 »
Success!
Ja... ongeduldigheid... :oops:
Re: Toon Recovery
Post by TheHogNL »
Ook in /etc/hostname en /etc/network/interfaces moet je de hostname aanpassen overigens.
Return to “Toon Hardware”
