Toon suddenly stopped measuring gas
Forum about Toon hardware, both versions 1 and 2 of Toon
Re: Toon suddenly stopped measuring gas
Postby Smiggel » Fri Nov 08, 2019 9:25 pm
Ok, so when I have the p1 cable disconnected, I see two errors on my Toon. Error C12 and C15. When I request the data from toon using hdrv_zwave?action=getDevices.json, I see the following:
   "dev_settings_device":{
      "uuid":"1c51433c-c280-4ed8-b0e2-5145734e469a",
      "name":"settings_device",
      "internalAddress":"settings_device",
      "type":"settings_device"
   "dev_5":{
      "uuid":"4496a984-c018-4d2d-b442-de7a440e4e70",
      "name":"HAE_METER_v2",
      "internalAddress":"5",
      "type":"HAE_METER_v2",
      "supportsCrc":"1",
      "ccList":"22 3c 3d 3e 56 60 70 72 7a 86 8b 73",
      "supportedCC":"22 3c 3d 3e 56 60 70 72 7a 86 8b 73",
      "nodeFlags":[
      "IsConnected":"1",
      "HealthValue":"10",
      "DeviceName":"HAE_METER_v2",
      "CurrentSensorStatus":"UNKNOWN"
   "dev_5.1":{
      "uuid":"46d45401-6d56-4ab8-b7e1-a10890dcab3f",
      "name":"HAE_METER_v2_1",
      "internalAddress":"5.1",
      "type":"HAE_METER_v2_1",
      "supportsCrc":"0",
      "ccList":"3c 3d 3e 72 86",
      "supportedCC":"3c 3d 3e 72 86",
      "nodeFlags":[
      "CurrentSensorStatus":"DISABLED",
      "CurrentGasFlow":"0.00",
      "CurrentGasQuantity":"4356550.00",
      "DeviceName":"HAE_METER_v2_1"
   "dev_5.2":{
      "uuid":"7b1259ef-b688-4078-a2a9-fb15f2f78bee",
      "name":"HAE_METER_v2_2",
      "internalAddress":"5.2",
      "type":"HAE_METER_v2_2",
      "supportsCrc":"0",
      "nodeFlags":[
      "CurrentSensorStatus":"UNKNOWN",
      "DeviceName":"HAE_METER_v2_2",
      "CurrentElectricityFlow":"NaN",
      "CurrentElectricityQuantity":"NaN"
   "dev_5.3":{
      "uuid":"6adff760-108b-4b60-83e2-8a23e1ae3124",
      "name":"HAE_METER_v2_3",
      "internalAddress":"5.3",
      "type":"HAE_METER_v2_3",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v2_3",
      "CurrentElectricityFlow":"240.00",
      "CurrentElectricityQuantity":"8148277.00"
   "dev_5.4":{
      "uuid":"09518844-7f66-4da4-be5b-feaf36e82c91",
      "name":"HAE_METER_v2_4",
      "internalAddress":"5.4",
      "type":"HAE_METER_v2_4",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v2_4",
      "CurrentElectricityFlow":"0.00",
      "CurrentElectricityQuantity":"7.00"
   "dev_5.5":{
      "uuid":"d092f00f-ea49-4a9c-9158-c3c3cc60e43e",
      "name":"HAE_METER_v2_5",
      "internalAddress":"5.5",
      "type":"HAE_METER_v2_5",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v2_5",
      "CurrentElectricityQuantity":"0.00"
   "dev_5.6":{
      "uuid":"5fe210d4-f7ea-4b4f-8231-fc91dad5b96f",
      "name":"HAE_METER_v2_6",
      "internalAddress":"5.6",
      "type":"HAE_METER[code][/code]_v2_6",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"HAE_METER_v2_6",
So, I reset the meter adapter now by holding the reset button for 10 seconds. Then I connected it again and get the same gas result:
   "dev_6":{
      "uuid":"e13a5f9d-d98b-4b09-9a8d-5a24d8a0f25b",
      "internalAddress":"6",
      "supportsCrc":"1",
      "nodeFlags":[
      "IsConnected":"1",
      "HealthValue":"10",
   "dev_6.1":{
      "uuid":"0dd83ef3-7ff0-41e8-91c8-e2a7777e2f5a",
      "internalAddress":"6.1",
      "supportsCrc":"0",
      "nodeFlags":[
      "CurrentSensorStatus":"OPERATIONAL",
      "DeviceName":"",
   "dev_6.2":{
      "uuid":"d9f5674e-acda-4ed8-850d-3a858c35b40c",
      "internalAddress":"6.2",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"",
   "dev_6.3":{
      "uuid":"24715b0f-14a1-4338-b779-23bef78f59da",
      "internalAddress":"6.3",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"",
      "CurrentElectricityFlow":"290.00",
      "CurrentElectricityQuantity":"8148328.00"
   "dev_6.4":{
      "uuid":"d8a3db4b-4aac-414e-b2f3-b4446682603a",
      "internalAddress":"6.4",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"",
   "dev_6.5":{
      "uuid":"1c9d2aa0-f2da-4042-9669-3794183f60f2",
      "internalAddress":"6.5",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"",
   "dev_6.6":{
      "uuid":"0624dc16-ddae-454e-bc74-e2ba2afff814",
      "internalAddress":"6.6",
      "type":"HAE_METER_v2_6",
      "supportsCrc":"0",
      "nodeFlags":[
      "DeviceName":"",
Smiggel
Postby TheHogNL » Fri Nov 08, 2019 9:36 pm
OK that means that or the smart meter isn't sending gas P1 data anymore or indeed the meteradapter is not working properly anymore.
Postby Smiggel » Fri Nov 08, 2019 9:39 pm
Ok, then there is a problem with the meteradapter. I called the network operator this morning. They checked my meter from a distance and they were able to read everything. They did not see anything strange at all. In fact, they read all data 2 days ago too.
So I guess I have to look for a new meteradapter then and see if that fixes the problem. :)
Thanks for helping me out!
Smiggel
Postby TheHogNL » Sat Nov 09, 2019 8:22 am
I'm not sure if the metercompany can tell from distance if the P1 is working properly. But you first try could be a new meteradapter indeed.
Postby Smiggel » Sat Nov 09, 2019 9:26 am
Thanks! I will see if I can get a new one somewhere.
Smiggel
Postby TerrorSource » Mon Nov 11, 2019 4:15 am
Smiggel wrote:Thanks! I will see if I can get a new one somewhere.
There’s someone on marktplaats selling all kinds of Toon Parts ;)
http://link.marktplaats.nl/m1463449362
TerrorSource
Postby Smiggel » Mon Nov 11, 2019 7:47 am
I have bought one already on marktplaats. Hopefully it will arrive soon. :-)
Thanks for the tip!
Smiggel
Postby Smiggel » Wed Nov 13, 2019 7:34 pm
The new MeterAdapter did not solve the problem. :-( Same output as before. So, I guess I have to contact my netbeheerder again, to have a look at my p1 meter port. :-(
Even when I pull the cable from the P1 port and check the results using http://<toon-ip>/hdrv_zwave?action=getDevices.json I still see the same result. Can it be that Toon itself is caching something?
Smiggel
Postby TheHogNL » Wed Nov 13, 2019 7:48 pm
Too bad... last solution can also be a factory reset of the toon.
Postby Smiggel » Wed Nov 13, 2019 7:49 pm
TheHogNL wrote:Too bad... last solution can also be a factory reset of the toon.
If I do a factory reset, will I have to root my Toon again?
Smiggel
Postby TheHogNL » Wed Nov 13, 2019 7:55 pm
The factory reset from the menu-software screen is root-friendly. A toon2 recovery (using the reset button procedure) isn't alway root friendly.
Postby Smiggel » Wed Nov 13, 2019 7:58 pm
Doing a factory reset now. I have the old Toon. :-)
Smiggel
Postby Smiggel » Wed Nov 13, 2019 8:31 pm
Ok, factory reset is done. Paired the newer meteradapter, as the old one did not want to pair anymore.
So far the result for gas quantity usage is still the same. :-(
    "dev_4.1": {
        "uuid": "5c98d23c-c05b-433c-8bcd-d7bd1a0c4291",
        "name": "HAE_METER_v2_1",
        "internalAddress": "4.1",
        "type": "HAE_METER_v2_1",
        "supportsCrc": "0",
        "ccList": "3c 3d 3e 72 86",
        "supportedCC": "3c 3d 3e 72 86",
        "nodeFlags": [],
        "CurrentSensorStatus": "OPERATIONAL",
        "CurrentGasFlow": "0.00",
        "CurrentGasQuantity": "4356550.00",
        "DeviceName": ""
Smiggel
Postby TheHogNL » Wed Nov 13, 2019 8:35 pm
Then it is for sure the smart meter :-(
Postby Smiggel » Wed Nov 13, 2019 8:37 pm
TheHogNL wrote:Then it is for sure the smart meter :-(
Yeah, was afraid of that. Will call my netbeheerder tomorrow.
Thanks for the help.
Smiggel
PreviousNext
Return to Toon Hardware
