Meteradapter research - Help needed
Forum about Toon hardware, both versions 1 and 2 of Toon
Postby TerrorSource » Fri Nov 22, 2019 7:11 pm
Hi Guys,
I'm doing a research on which meteradapter works with what smart meter and what functionality is availble for which type of meteradapter.
Could you all please fill in the following Google Forms to help me?
No personal data is asked or saved.
https://forms.gle/5HPHDCBuVwFwsBMT8
Hallo iedereen,
Ik ben aan het onderzoeken welke meteradapter met welke slimme meter werkt en welke functionaliteit er beschikbaar is voor welk type meteradapter.
Zouden jullie mij willen helpen door onderstaand Google Forms formulier in te vullen?
Er worden geen persoonlijke gegevens gevraagd of opgeslagen.
TerrorSource
Re: Meteradapter research - Help needed
Postby TerrorSource » Sun Dec 29, 2019 8:22 pm
Bump :) only received a couple of replies.
Please help me research the meteradapter more
TerrorSource
Postby Toonz » Sun Dec 29, 2019 8:47 pm
what do you expect to learn from this?
Isn't the only question which meteradapter supports Zon op Toon (and we know this already)?
Postby marcelr » Sun Dec 29, 2019 11:13 pm
Years ago I compiled a small list for the (then available) meter adapters and corresponding firmwares:
https://www.domoticaforum.eu/viewtopic. ... 255#p79033
Only the 6500-1400-6000 type in this list supports Zon op Toon. Later versions all support it.
Postby TerrorSource » Mon Dec 30, 2019 12:37 pm
Toonz wrote:what do you expect to learn from this?
And which meteradapter works with what type of smart meter.
As a Kaifa MA105A can work with all types of meteradapter while a Landis Gyr E350 is picky and only works with meteradapters with support for DSMR 5.0 and newer.
TerrorSource
Postby hansgrave » Mon Dec 30, 2019 5:14 pm
Done, firmwareversion of the Meteradapter was hard to find... Instellingen-->Energiemeting-->Meetmodules-->Meetmodule 1
Homey, rooted Toon 1 and Domoticz.
hansgrave
Postby Templar » Tue Dec 31, 2019 1:33 am
So the deal is to know which smart meters and meteradapters run on DSMR 5.0?
Templar
Postby TerrorSource » Thu Jan 02, 2020 1:21 pm
Not only that, i used that for an example.
Mostly i would like to know which meteradapter works with what smart meter as not all meteradapters work with all smart meters.
TerrorSource
Postby NLKris » Tue May 12, 2020 1:27 pm
So I tought that if there were 2 flames on the 'meetmodule' you'll be fine with the Smartmeter. Later I found out that some 1 flame meters are also working.
Since last month I made a list for myself. If i'm right I got a Smart Meter with protocol 3.0 or 4.0? (Have a Kaifa E0025)
Anyways, this is the info I got:
1 flame WORKING:
6500-1300-7200
*I had ever one older than 6500-1300-7200, that was the one not working. The difference was in firmware, but I did not write that down...
2 flame WORKING:
6599-1500-0201
6599-1700-0600
6599-1700-0602
*Think that newer will work too/all the 2 flames wil work on mine.
NLKris
Return to Toon Hardware
