HTTPS enabled on Toon
Posted: Thu Dec 28, 2017 4:34 pm
by Toonz
after some further digging I found out that Toon does support https in principle but it never worked because the public root CA certificates are not installed (typically comes with your browser).
The only root certificates installed are the ones which are needed to validate Quby's own servers.
So, in order to get https calls to work you will need to add manually the right certificates to the ssl certificate store with a text editor.
It is located here on Toon: /etc/ssl/certs/ca-certificates.crt
Example: xml.buienradar.nl is using a certificate issued by DigiCert. You can find out who issued the certificate by clicking on the 'lock' icon in your browser and press view certificates.
In order to access buienradar Toon must have the root CA from DigiCert added to the certificate store (certificate name: DigiCert Global Root CA).
Root certificates from most common trusted issuers can be found in this csv file : ccadb-public.secure.force.com/mozilla/I ... portPEMCSV
When this file is opened in Excel the root CA of Digicert can be found at row 49.
Column AC contains the digital certificate (pem).
Append the contents of this field to the certificate file on Toon (remove the quotes from the csv file):
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
After that all http/https calls to the buienradar server will work with the original, unmodified buienradar app 8.2.0 (so even http redirects to https will work automatically)
This approach will work for any webserver you want to access from Toon via https.
I also found new QML code from Quby introduced in version 4.9 which supports HTTP(S) calls with the POST method to fill in webforms automatically.
What's next:
- create a new version of buienradar, reverting back the latest changes in 8.2.1 and installing this certificate.
- major revision of the afvalwijzer app to support more websites automatically and add more certificates (remove the need for wget and cron jobs)
Toon.
Re: HTTPS enabled on Toon
Posted: Fri Dec 29, 2017 4:34 pm
by jozg
Hello Toonz,
Thanks.
With this certificate, my (old) buienradar app is working again.
Good work!.
Jos.
Posted: Fri Dec 29, 2017 9:43 pm
by gerardzh
Thanks!
Posted: Sat Dec 30, 2017 12:20 am
by michel30
Super,
This works super, I uninstall 8.2.1 and install back 8.2.0 and add the certificate everything works like it was before.
Thanks Toonz for sharing this information.
Michel
