login as: root
root@172.20.20.17's password:
qb-659916001600-1804A01CTF:~# curl -Nks https://raw.githubusercontent.com/ToonSo
ftwareCollective/update-rooted/main/update-rooted.sh -o /root/update-rooted.sh
qb-659916001600-1804A01CTF:~# sh /root/update-rooted.sh
Welcome to the rooted Toon upgrade script. This script will try to upgrade your Toon using your original connection with Eneco. It will start the VPN if necessa ry.
Version: 4.42 - TheHogNL - 17-02-2021
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
You are currently running version 4.9.124 on a nxt with flavour ene
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3 .0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3. 20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.10.9 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.17.11 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2 .11 5.5.7 5.9.6 5.13.9 5.13.12 5.15.6 5.18.8 5.22.14 5.25.8 5.28.6 5.28.9 5.30.4 5.33.9 5.39.7 5.41.1
Which version do you want to upgrade to?
5.0.6
Alright, I will try to upgrade to 5.0.6
Could not enable VPN in a normal reasonable time!
DEBUG information:
default via 172.20.20.1 dev wlan0 metric 10
172.20.20.0/24 dev wlan0 scope link src 172.20.20.17
192.168.208.0/20 dev tap0 scope link src 192.168.210.132
192.168.208.0/20 via 192.168.208.1 dev tap0 metric 1024
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost qb-659916001600-1804A01CTF
192.168.208.1 feed.hae.int feed
END DEBUG information
Hey you got a different address block for the VPN (192.168.208.1)
Probably because your own internal network is 172.20.20.0/24 which is normally the range of the VPN of the toon.
Didn't knew this was possible.
Is it for you easy to use another internal network range for your home wifi (in the 192.168. range)?
If not, I will need to change the update script to work in these situations.
login as: root
root@10.53.100.29's password:
5.0.6
DEBUG information:
default via 10.53.100.254 dev wlan0 metric 10
10.53.100.0/24 dev wlan0 scope link src 10.53.100.29
qb-659916001600-1804A01CTF:~# sh /root/update-rooted.sh -v 4.10.9
Forcing version: 4.10.9
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Waiting to finish. Sometimes this takes a minute or two ...
Prepare failed. Please check the logs at /mnt/data/update/upgrade-nxt.sh.log
