Upload RRA Data to Toon (Gas, water, electricity usage)
If you don't know where to post, post here.
georon
Post by georon »
I am trying to upload data to Toon (my gas meter for now)
Can anyone provide me with a sample of rra data?
Or an example on using http://toonip/hcb_rrd/testSet.html or http://toonip/hcb_rrd?action=setRrdData ... &something?
I am trying to inject data domoticz to my toon for display purposes.
Reason: I live in Belgium and my gas meter is outside the building. So I created a battery powered solution with a reed switch to measure my gas usage in domoticz.
I am unable to attach a electricity infrared because of a plexiglass casing around my meter (example: see https://youtu.be/pLdCl3dx-EI at 30secs.)
Second hand Boxx sensors are not available yet
Thanks in advance
Re: Upload RRA Data to Toon (Gas, water, electricity usage)
Post by TheHogNL »
You could also just let a LED pulse at the right frequency to feed your Toon analog sensor for the gas input, based upon the information from domoticz and the reed switch. You probably can also just feed the electric pulses directly into the toon meteradapter, just like the zonoptoon methode somewhere else in the forum
Return to “Toon miscellaneous”
