Toon thermostat data to grafana
If you don't know where to post, post here.
Postby TheHogNL » Thu Oct 31, 2019 3:49 pm
I created a script to push some thermostat data to grafana using a free provider corlysis.com. Go there, register a free account and create an empty time-database.
Then run this script on your Toon (after entering your corlysis details in the variables in the top of the script). You can run this script manually or from inittab or something.
#!/bin/sh
DB="enter-db-name"
USER="enter-db-username-default=token"
PASSWORD="enter-db-password"
### don't change below this line ###
HOSTNAME=`hostname`
URL="https://corlysis.com:8086/write?db=$DB"
while true
do
        OUTPUT=`curl -Nks "http://localhost/happ_thermstat?action=getThermostatInfo"`
        CURTEMP=`echo $OUTPUT | sed 's/.*"currentTemp":"\([0-9]*\)".*/\1/'`
        CURTEMP=`awk "BEGIN {print ($CURTEMP)/100}"`
        SETTEMP=`echo $OUTPUT | sed 's/.*"currentSetpoint":"\([0-9]*\)".*/\1/'`
        SETTEMP=`awk "BEGIN {print ($SETTEMP)/100}"`
        BOILERSETTEMP=`echo $OUTPUT | sed 's/.*"currentInternalBoilerSetpoint":"\([0-9]*\)".*/\1/'`
        BURNERSTATE=`echo $OUTPUT | sed 's/.*"burnerInfo":"\([0-3]*\)".*/\1/'`
        MODULATIONLEVEL=`echo $OUTPUT | sed 's/.*"currentModulationLevel":"\([0-9]*\)".*/\1/'`
        POST="thermostat,hostname=$HOSTNAME curtemp=$CURTEMP,settemp=$SETTEMP,boilersettemp=$BOILERSETTEMP,burnerstate=$BURNERSTATE,modulationlevel=$MODULATIONLEVEL"
        RESULT=`curl -Nksi -XPOST $URL -u "$USER:$PASSWORD" --data-binary "$POST"`
        sleep 60
done
Then head back to corlysis website and create your Grafana dashboard and import this JSON file to create my default dashboard. You would then see pretty graphs!
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": "-- Grafana --",
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "type": "dashboard"
  "editable": true,
  "gnetId": null,
  "graphTooltip": 0,
  "id": 1079,
  "iteration": 1572532026834,
  "links": [],
  "panels": [
      "aliasColors": {},
      "bars": false,
      "dashLength": 10,
      "dashes": false,
      "datasource": null,
      "fill": 1,
      "gridPos": {
        "h": 9,
        "w": 12,
        "x": 0,
        "y": 0
      "id": 2,
      "legend": {
        "avg": false,
        "current": false,
        "max": false,
        "min": false,
        "show": true,
        "total": false,
        "values": false
      "lines": true,
      "linewidth": 1,
      "links": [],
      "nullPointMode": "connected",
      "percentage": false,
      "pointradius": 5,
      "points": false,
      "renderer": "flot",
      "seriesOverrides": [
          "alias": "Burner state",
          "yaxis": 2
          "alias": "Modulation level",
          "yaxis": 2
          "alias": "Boiler set temp",
          "yaxis": 2
      "spaceLength": 10,
      "stack": false,
      "steppedLine": false,
      "targets": [
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "previous"
              "type": "fill"
          "measurement": "thermostat",
          "orderByTime": "ASC",
          "policy": "default",
          "refId": "A",
          "resultFormat": "time_series",
          "select": [
                "params": [
                  "boilersettemp"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "key": "hostname",
              "operator": "=~",
              "value": "/^$Hostname$/"
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "previous"
              "type": "fill"
          "refId": "B",
          "select": [
                "params": [
                  "burnerstate"
                "type": "field"
                "params": [],
                "type": "mean"
                "params": [
                  "*25"
                "type": "math"
          "tags": [
              "key": "hostname",
              "operator": "=~",
          "alias": "Current temperature",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "previous"
              "type": "fill"
          "refId": "C",
          "select": [
                "params": [
                  "curtemp"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "key": "hostname",
              "operator": "=~",
          "alias": "Setpoint temperature",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "previous"
              "type": "fill"
          "refId": "D",
          "select": [
                "params": [
                  "settemp"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "key": "hostname",
              "operator": "=~",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "previous"
              "type": "fill"
          "refId": "E",
          "select": [
                "params": [
                  "modulationlevel"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "key": "hostname",
              "operator": "=~",
      "thresholds": [],
      "timeFrom": null,
      "timeShift": null,
      "title": "Thermostat values - $Hostname",
      "tooltip": {
        "shared": true,
        "sort": 0,
        "value_type": "individual"
      "type": "graph",
      "xaxis": {
        "buckets": null,
        "mode": "time",
        "name": null,
        "show": true,
        "values": []
      "yaxes": [
          "format": "celsius",
          "label": null,
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
          "format": "short",
          "label": null,
          "logBase": 1,
          "max": "100",
          "min": "0",
          "show": true
      "yaxis": {
        "align": false,
        "alignLevel": null
  "schemaVersion": 16,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": [
        "allValue": null,
        "current": {
          "text": "choose our toon",
          "value": "choose our toon"
        "datasource": "influx_auto_Toon",
        "hide": 0,
        "includeAll": false,
        "label": null,
        "multi": false,
        "name": "Hostname",
        "query": "show tag values with key = \"hostname\"",
        "refresh": 1,
        "regex": "",
        "skipUrlSync": false,
        "sort": 0,
        "tagValuesQuery": "",
        "tags": [],
        "tagsQuery": "",
        "type": "query",
        "useTags": false
  "time": {
    "from": "now/d",
    "to": "now"
  "timepicker": {
    "refresh_intervals": [
      "5s",
      "10s",
      "30s",
      "1m",
      "5m",
      "15m",
      "30m",
      "1h",
      "2h",
      "1d"
    "time_options": [
      "5m",
      "15m",
      "1h",
      "6h",
      "12h",
      "24h",
      "2d",
      "7d",
      "30d"
  "timezone": "",
  "title": "Toon dashboard",
  "uid": "Nru7--AZk",
  "version": 7
Return to Toon miscellaneous
