Display energy delivery info
If you don't know where to post, post here.
phoenixb
Post by phoenixb »
As far I know it's not possible to get info on the toon from the solar panels without an extra measuring adapter.
Without you see on the toon only the actual usage, when you are delivering back it's the value - -
But I have install the telegram bot app now (works great btw) and received from telegram my delivery back info to the grid (see photo)
So the P1 info from the adapter is somewhere going to the toon because this info is correct what is see.
Is there an option to display this value on the toon?
__________________
Re: Display energy delivery info
Not at the moment, unless we find a way to properly 'inject' these data into the Toon realtime (not so straightforward)
phoenixb
Post by phoenixb »
And only an simple dashboard tile with the actueel info without any log function?
__________________
that's doable, you can look at the Toonbot app for inspiration maybe?
Return to “Toon miscellaneous”
