Toon App: Water
Re: Toon App: Water
Hello everyone,
I have a problem with Toonwater, after a few days I can no longer access the wemos via the ip address.
at these moments Toon is still connected (with the wemos).
but then Toon also spontaneously loses the connection, a hard reset of the wemos is the solution.
Does anyone have a problem with this or a solution?
Attached screenshot of the wemos info page
- Info pagina Toonwater
- Toonwater.png (124.7 KiB) Viewed 6384 times
- Advanced Member
Re: Toon App: Water
You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
Re: Toon App: Water
where can i find the latest version?oepi-loepi wrote:You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
I have version 1.3.15 is this not the last one?
Re: Toon App: Water
First place I would look is the start postKrisrock wrote:where can i find the latest version?oepi-loepi wrote:You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
Re: Toon App: Water
TheHogNL wrote:First place I would look is the start postKrisrock wrote:where can i find the latest version?oepi-loepi wrote:You are using a very old software. In the old version the wifi is nit reconnecting when losing the wifi. In the newer versions it is attempting to reconnect. So update to the latest version.
there is the same version as what I described in the above post.
- Advanced Member
Re: Toon App: Water
Ok, from what i understood from your screenshot was the very old version. I guess you have only send part of the text there. If you have set the static ip and the wifi is lost, the unit will try to reconnect automatically. Try to run the upgrade with the latest file, just to be sure.
Also make sure that you do not have another divice in hour network assigned to the same static ip.
- Member
Re: Toon App: Water
Ik heb alles nagelopen maar krijg er geen leven meer in. Adviseer je om alles opnieuw te kopen of eerst de sensor?oepi-loepi wrote:Wat heb je gedaan? Heb je een update gedaan of iets anders? Als je geen rood lampje krijgt als je iets van metaal tegen de ensor aanhoud (aan de blauwe kant). Dan is ook een draad van de 5V of 0V los (sensor bruin en blauw). Of de sensor is defect.
Dus even de sensor losnemen uit de houder en iet van metaal tegen de sensor aanhouden. Als hij het dan nog niet doet dan even de solderingen en de bedrading nalopen
Ik zie wel dat hij contact heeft met het WiFi netwerk.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Re: Toon App: Water
update done again (see attachment for result)oepi-loepi wrote:Ok, from what i understood from your screenshot was the very old version. I guess you have only send part of the text there. If you have set the static ip and the wifi is lost, the unit will try to reconnect automatically. Try to run the upgrade with the latest file, just to be sure.
the IP address (21) has been reserved for Tooon water. so this must be good.
I also don't see any apartments that come close with this ip address (in the router)
- update 2
- 2.jpg (113.28 KiB) Viewed 6157 times
- update 1
- 1.jpg (93.96 KiB) Viewed 6157 times
Re: Toon App: Water
Ik heb het zelfde gehad, waarschijnlijk is mijn sensor defect gegaan door vocht.Bruce the boss wrote:Ik heb alles nagelopen maar krijg er geen leven meer in. Adviseer je om alles opnieuw te kopen of eerst de sensor?oepi-loepi wrote:Wat heb je gedaan? Heb je een update gedaan of iets anders? Als je geen rood lampje krijgt als je iets van metaal tegen de ensor aanhoud (aan de blauwe kant). Dan is ook een draad van de 5V of 0V los (sensor bruin en blauw). Of de sensor is defect.
dit kan gebeuren omdat ik de tip van sensor moest bewerken voor een juiste meting.
sensor vervangen en iets veerder gestopt met schuren, en een plak bankje er tussen (zodat de sensor niet meer in aanraking kan komen met condens van de meter)
- Advanced Member
Re: Toon App: Water
Inderdaad. De wifi is prima, bedrading heb je nagelopen. Dan blijft de sensor over..Krisrock wrote:Ik heb het zelfde gehad, waarschijnlijk is mijn sensor defect gegaan door vocht.Bruce the boss wrote:Ik heb alles nagelopen maar krijg er geen leven meer in. Adviseer je om alles opnieuw te kopen of eerst de sensor?oepi-loepi wrote:Wat heb je gedaan? Heb je een update gedaan of iets anders? Als je geen rood lampje krijgt als je iets van metaal tegen de ensor aanhoud (aan de blauwe kant). Dan is ook een draad van de 5V of 0V los (sensor bruin en blauw). Of de sensor is defect.
- Advanced Member
Re: Toon App: Water
Nieuwe versie in de toonStore. Ik werd erop gewezen dat in dimstand de grafiek van water en die van gas hetzelfde zijn. Kleine aanpassing gedaan in versie 1.1.17
Re: Toon App: Water
Still have after the latest firmware that sometimes I can't connect. (with the Wemos)
I can also see it in Toon that the graphs become gray
- Advanced Member
Re: Toon App: Water
Maybe the wifi at the wemos is not stable?Krisrock wrote:Still have after the latest firmware that sometimes I can't connect. (with the Wemos)
Re: Toon App: Water
The Wemos is 2.5 meters away from the router.
Surely the reception should be good then?
info from the wemos: wifi strength -66
will look into getting an external antenna for the wemos or will this not help?
- Advanced Member
Re: Toon App: Water
The strenght of -66 is not the best. Maybe your wemos has a fault.Krisrock wrote:The Wemos is 2.5 meters away from the router.
