Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Joskep wrote:And suddenly it works again, i see the icon of plastic, and thats correct for today.
Don'y know how, but it works :D
Good timing, was about to start looking into this :-) Thanks for the feedback
Grutte wrote:Hey,
Is it possible that the Omrin - https://www.omrin.nl/bij-mij-thuis/afva ... alkalender
Is not working anymore? I have put omrin.htm in root/waste/ but cant get it to work.
Still working fine here. Quick manual:
login in at omrin.nl with your zipcode / housenumber.
Right-click somewhere in the space to the left of your calendar table
Click 'Save as'
Save as 'omrin.htm'
Copy omrin.htm to the toon in /root/waste/omrin/htm
Goto to the afvalwijzer app on Toon, goto the settings screen.
Check you have rovider 21 and press Opslaan.
The data should be visible after a short while.
Note: I tested with the Edge browser on Windows. Could be that other browsers give different output which the app can't handle.
Note 2: while testing I discovered a bug in the omrin handling routine, especially if a month has no collection dates for a specific waste type at all. Will fix that shortly.
Kind regardz,
I fixed the omrin bug, will be published in a new version soon (issue caused by a new name for the paper category)
flamingbob wrote:Same problem here. Also see no traffic to Meerlanden (16)
My own calander does work. Changing the provider also shows queries. As soon as I go back to 16 no lookups at all for that provider. Think it happened somewhere between 4.6x
Hi ,
Meerlanden changed from service provider waste2go to ximmio. The good News, I recently implemented the ximmio functionality for RAD Hoeksewaard which also works for Meerlanden.
I will package this in a new release today together with the fix for omrin.nl
release 4.63 is available in the ToonStore.
Changelog:
- fix for Meerlanden (16) (they changed backend service provider)
Update the app and go to the settings page, change any item and press 'Opslaan' (this to update the settings file to add a new tag ICSurl)
On your PC goto https://www.meerlanden.nl and login with your zipcode/housenr
when you see your calendar data, press 'Zet in agenda' at the right top of the month calendar
press 'Kopieer' to copy the full url to your calendar ICS file.
On the Toon you need to edit the file /mnt/data/tsc/wastecollection.userSettings.json
Paste the full url between the two "" after the "ICSUrl" tag.
The part should now look like "ICSUrl":"https://wasteprod2api.ximmio.com/api......"
Save the JSON file.
On Toon, goto the Menu, Instellingen, TSC, Restart GUI et voila.
- fix for omrin.nl (21) (paper category was not shown properly due to website change)
No need to update for other users.
Kind regardz,
flamingbob
Post by flamingbob »
Toonz wrote:Hi all,
Changelog:
Save the JSON file.
Kind regardz,
Thanks! Fun how they change providers each year. Will test it at home tonight.
Tebogo
Post by Tebogo »
marcelr wrote:Had hetzelfde probleem. Cure afvalbeheer heeft het protocol veranderd. Zit nu bij mijnafvalwijzer.nl
Even je afvalverwerker veranderen van 3 in 1 en dan doet-ie het weer.
@Toonz: Ik denk dat je optie 3 gevoegelijk uit de afvalkalender app kunt knikkeren.
Yep, dit was de oplossing! Niet op 3, maar optie 1 kiezen als je Cure als afval-ophaaldienst hebt.
@Toonz: Optie 3 kan verwijderd worden denk ik.
Bedankt!
Salih547
Post by Salih547 »
hallo,
Ik krijg niks te zien op de afvalcalender hij laad niks blijt wit, kan mij iemand hepen mijn afval ophaler is optie 25 area-afval.nl.
gegroet,
salih
version 4.64 will be available in the ToonStore soon with a fix for twenteilieu.nl.
Solving a bug with I accidentally introduced in a recent version.
Kind regardz,
Salih547 wrote:hallo,
gegroet,
salih
voor area-afval moet je de ICS file downloaden van de website en kopieren naar Toon (ieder jaar).
Nu het goede nieuws, ze geven tegenwoordig ook een link naar de kalender die online kan worden opgehaald.
Dit heb ik onlangs al gemaakt voor RAD Hoeksewaard en dit werkt ook prima voor area-afval waardoor je niet meer zelf de kalender file steeds hoeft te kopieren.
Volg dezelfde procedure als voor RAD Hoeksewaard en kies provider 41 (in plaats van 25):
- select provider 41 and press 'Opslaan' (this to update the user settings file with a new tag ICSurl)
On your PC goto https://www.area-afval.nl/voor-bewoners ... alkalender and login with your zipcode/housenr
when you see your calendar data, press 'iCal' at the right top of the month calendar
On the Toon you need to edit the file /mnt/data/tsc/wastecollection.userSettings.json using your tool of choice (Winscp.exe for example)
Paste the full url you just copied between the two "" after the new "ICSUrl" tag.
This part should now look like "ICSUrl":"https://wasteapi.ximmio.com/api/....."
Save the /mnt/data/tsc/wastecollection.userSettings.json file.
On Toon, press Menu, Instellingen, TSC, Restart GUI and everything should work.
EDIT: de oude optie met provider 25 werkt natuurlijk ook nog, daarvoor moet je de iCal file downloaden van area-afval.nl en kopieren naar toon als : /root/waste/waste_calendar.ics
Nickosz
Post by Nickosz »
cygnusx wrote:i made a mockup of how i think the afvalwijzer app should look like:
The color of the icon is dependant of the kind of garbage. It only gets this state the day before around 17 o clock. When there is no upcoming garbage, the icon would be gray so it's clear that there is no attention needed. With plastic it is orange etc.
This is how it looks in dim state. When there is no upcoming garbage, then no icon/text. Otherwise a gray icon with the right container.
Multiple containers together? Then a text like "Grijs & Plastic".
What do you guys think?
WAUW can you help me, i want this too, but i do not get any icons when my display is at dim mode.
Hi welcome to this forum.
You need to configure the afvalwijzer app for your city / waste collecting company.
To give you a detailed advice I need to know in which town you live or which company is collecting your waste (I do not need to know your postcode/housenr).
If you already did that and you see waste collection dates on the screen then just wait.
After configuring the app you will need to restart the Toon gui to have the icons show up after 6 minutes if applicable.
Or simply wait, around 18:00 each day the icons will be refreshed and shown for the collection the next day
Kind regardz,
Bassie
Post by Bassie »
Toonz wrote:Hi all,
...- fix for Meerlanden (16) (they changed backend service provider)....
Works! Thanks again for your hard work!!
Jgcw
Post by Jgcw »
Sinds vandaag mn geroote en toon mogen ontvangen.
Ik woon in de Ooij bij Nijmegen de dar komt hier het afval ophalen.
Als ik bij de instellingen alles ingevuld heb en op opslaan druk,
Is het even gegevens aan het ophalen en dan een wit scherm.
Ik heb contact gehad met oempie loempie
En hem een screenshot gestuurd
Hij gaf aan dat er een slash teveel in het internet adres stond
Echter als ik erop druk dat adres wil ie de nul erachter veranderen maar niets aan het adres.
Graag zou ik willen weten wat ik moet doen
Alvast bedankt
Go to the Dar website, enter your zipcode/housenr.
Go to 'Naar jaar-en maandkalender'
Go to 'zet inzameldata in uw agenda'
Write down the ical number (last part of the link under 'Synchroniseren')
On Toon go to the Afvalkalender instellingen, select waste provider 7 and fill the ical number noted above in the row below.
Press 'Opslaan' and you should see data after a short period.
Kind regardz,
