Toon app: boiler status
Re: Toon app: boiler status
Postby gielie » Tue Jan 19, 2021 11:29 pm
TheHogNL wrote:
Doerakker wrote:After updating firmware to 5.39.7 some values show NAN
Is this a known issue ? See attached screenshot
Yes. For unknown reason the Toon developers removed boiler water in and out from the information available for us. Maybe to save disk space because they don't use those values themselves in a regular toon.
That’s a bummer, are you guys able to bring this back or are we doomed to a previous firmware? I just did the update without reading this. Is there a easy way to downgrade or do I have to do a recovery?
gielie
Postby Toonz » Wed Jan 20, 2021 12:08 am
there is no easy way to downgrade. Best option is to do a recovery and then update to 5.33.9 and stay there forever.
Is this really that important? You can also consider getting the OTGW board, that will give you full access to the OT protocol independent from Toon.
Postby Ierlandfan » Thu Jan 21, 2021 10:44 am
Can we modify the logging package that MarcelR created long time ago to use as a proxy to log the Opentherm traffic without interfering with the normal behaviour of Toon? Solves a lot of problems at once and in the future.
Ierlandfan
Postby Toonz » Thu Jan 21, 2021 1:50 pm
Ierlandfan wrote:Can we modify the logging package that MarcelR created long time ago to use as a proxy to log the Opentherm traffic without interfering with the normal behaviour of Toon? Solves a lot of problems at once and in the future.
that is not possible as the data stream used in that process is not available anymore since firmware 3.6 or so. The only option is to install an OTGW at the moment. Or downgrade to 5.33.9 and stay there forever
Postby mogwai » Thu Jan 21, 2021 10:32 pm
I made the same stupid mistake to upgrade to 5.39.7 (hoping it would solve the rather frequent reboots of my Toon1) without looking at the forum first. Now I also lost the boiler temperature logging :(. One of the reasons to initially get the Toon was to get access to the opentherm data without having to add yet another device mingling with the opentherm traffic...
So if you guys see any option to revive this functionality without downgrading this would be highly appreciated!
mogwai
Postby mennozon » Mon Jan 25, 2021 6:03 pm
mogwai wrote:So if you guys see any option to revive this functionality without downgrading this would be highly appreciated!
I've downgraded only the thermstat application by downloading the version I previously used, this seems to work but I only tested it for a day so please be aware that things might be broken by doing this.
So far everything seems okay (I can read boiler temperatures again and I have heating working) but the binary increased more than 4 times from the previous version, makes you wonder what they've all changed..
Steps I've used were enable VPN with the update-rooted script, wget the file, let opkg downgrade it and reboot.
sh update-rooted.sh -o
wget http://feed.hae.int/feeds/qb2/POOL/happ-thermstat_1.2404-master_qb2.ipk
opkg --force-downgrade install happ-thermstat_1.2404-master_qb2.ipk
mennozon
Postby gielie » Thu Jan 28, 2021 12:05 pm
Your a life saver, this works like a charm. Let’s see how long this keeps working.
Maybe the dev guys can use this for a further update?
I use the temp in/out to see if my t delta is okay.
@mennozon Thanks for the solution.
gielie
Postby TheHogNL » Thu Jan 28, 2021 2:14 pm
My point of view is to better use another type of IOT to monitor your temperatures of the heating system.
Force downgrading the happ-thermstat package is ok, but we don't know how that can block other thing or newer updates in the future. So I would never put that in the update script.
For there is no real reason to update (no new features or bugfixes), we could also just block any future update (until maybe finally new features are added). Is that a better idea?
Postby Toonz » Thu Jan 28, 2021 2:44 pm
TheHogNL wrote:For there is no real reason to update (no new features or bugfixes), we could also just block any future update (until maybe finally new features are added). Is that a better idea?
I believe only a very small number of users is actually using the boiler in/out values. Better create an option in de TSC menu to opt-out of future firmware upgrades and let the majority of users update when new firmware is available.
Downgrading just happ-thermstat is asking for problems in my view (the risk will be increased with each new firmware). My 2 cents.
Postby TerrorSource » Thu Jan 28, 2021 3:46 pm
Agree with Toonz,
forcing a downgrade of a package isn't a good solution. i would prefer to restore the Toon to 5.33.9 via ToonRecovery and never upgrade to newer versions.
When you force a package downgrade after each firmware the difference between the latest version and the old, downgraded package, will become greater and greater with no sight on what else is using the package or any dependencies.
It might cause your Toon to become unstable.
TerrorSource
Postby gielie » Thu Jan 28, 2021 4:06 pm
@Devs, i see your point and that is fine, for me this is the easiest way to get this option back with the least effort. My time of opening the Toon and play with it has past.
I won't update to newer versions anymore, my Toon1 has become so old and slow maybe its about time to look for something else/new maybe a prehacked Toon2.
gielie
Postby glsf91 » Thu Jan 28, 2021 5:34 pm
Toonz wrote:I believe only a very small number of users is actually using the boiler in/out values. Better create an option in de TSC menu to opt-out of future firmware upgrades and let the majority of users update when new firmware is available.
I like the opt-out feature in the TSC menu
glsf91
Postby knug2 » Sun Jan 31, 2021 10:47 pm
Same issue here.
I'm using the OT information to control my custom build zone-regulation.
I also have a custom programmed OT arduino to read out all the OT traffic between boiler and Toon ( and to start/override the TOON when I'm zone-regulating ). However, i'm using the Toon boiler setpoint( which is a result of the Toon PID output ) value to control valves that lead to my livingroom where the Toon is located.
So I really need to revert back to the previous firmware version, or I will downgrade the Thermstat app as mentioned above.
knug2
Postby knug2 » Sun Jan 31, 2021 11:03 pm
Thanks man! Your indeed a lifesaver in my case ;)! Got everything working again. Hopefully this will be solved in future updates?
knug2
Postby mogwai » Sun Feb 07, 2021 10:47 pm
Today I finally had some time to give it a try. It works like a charm, thanks!
mogwai
PreviousNext
Return to Toon Apps
Users browsing this forum: oepi-loepi and 1 guest
