Toon app: Buienradar
edwinth
Re: Toon app: Buienradar
Post by edwinth »
Hello Toonz,
It was me. I thought that clicking on the icon gave me the weather but it's the radar.(feature request maybe ?)
The screen for adding the widgets made me confused because the text overlaps.
Keep up the good work!
Thanks,
Edwin
A new version (8.5.8) is available in the ToonStore now. The input file from buienradar has a non-standard format sometimes which has been reported to but not fixed by buienradar.
This version handles it properly now.
Changelog:
- fix for the 'regenverwachting' tile, handling bad input correctly now, thanks glsf91
whizzz63
Post by whizzz63 »
Thanks for the update. Would you please be so kind to look at the map in the Buienradar app. (Actuele Temperatuur, Motregenradar, Pollenradar enz). Zuid_Limburg isn't visible. Could you fix this?
whizzz63 wrote:Thanks for the update. Would you please be so kind to look at the map in the Buienradar app. (Actuele Temperatuur, Motregenradar, Pollenradar enz). Zuid_Limburg isn't visible. Could you fix this?
can be fixed, probably caused by a new size of the maps. Will have a look.
Hi all, a next maintenance release is available in the ToonStore:
Changelog version 8.5.9
- resized the radarimages on a Toon 2 so that the most southern part of Limburg is visible as well :-)
- renamed label of the Regenverwachting tile so it doesn't overlap anymore
- fixed +3h radarimages on a Toon 2 (nobody noticed it didn't work anymore?)
whizzz63
Post by whizzz63 »
Thanks a lot for the update! It looks great and the 3 hours forecast works fine!
version 8.5.11 is available in the ToonStore with a small cosmetic change.
Changelog:
- on the Rain prediction tile, the Y-axis label font size has been increased
version 8.5.12 is available in the ToonStore.
Changelog:
- functionality to enter lon/lat coordinates via scanning a QR code has been removed
No need to update for existing users but be aware that that piece of functionality will not work anymore in the future
markismus
Tiles missing
Post by markismus »
The tiles for buienrader are missing.
Installed version TSC 5.39.7, update-rooted.sh 4.42, buienradar 8.5.12, toonstore 5.1.0.
I ran `sh update-rooted.sh -f`, `reboot` , `shutdown -r now`, but to no avail.
I switched native weather to on, since the weather info is missing from the clock tile*, too. No result, though.
______________________________
* Wasn't it at the clock tile? Or was it a separate tile. If so, that one is missing, too.
Blacky's Boss
Post by Blacky's Boss »
I think Buienradar is broken?
Last update on my Toon was 15:40, my dads at 14:20 and a neighbours one at 14:50. Time is now 20:45.
nothing wrong with the app, just an issue with the Buienradar data feed. Usually they fix it within a day but not sure in the weekend.... patience.....
website gives an error that the url is invalid, let me check if something has changed
the URL used in the app (https://xml.buienradar.nl) is discontinued and should be replaced by https://data.buienradar.nl/1.0/feed/xml.
New version is ready and will be in the ToonStore very very soon :-)
Blacky's Boss
Thanx :D Supersnelle service :mrgreen:
version 8.5.13 is ready to be published in the ToonStore fixing the buienradar data feed URL.
Will be visible when the change has been approved.
Toonz.
Buienradar 8.5.13 is now available in the ToonStore.
No new functionality, just fixing the source URL.
