Toon app: Buienradar
Re: Toon app: Buienradar
Postby Toonz » Tue Mar 13, 2018 11:41 pm
ronalddehaan wrote:Hi Toonz,
Just a quick question, I don't know if it's been asked before or not, but is it normal that the Buienradar app is 'updated' every day?
I am getting 'update' messages in my inbox on a daily bases (at 01.00) that the app has been updated. The version, however, only changes ever so often.
Please let me know :)
This is a mistake in the buienradar 8.3.3 installation. It contains a version.txt file with 8.3.2 instead of 8.3.3.
Will fix this in the buienradar 8.3.4 shortly (and add the EU map to it).
You could manually edit the version.txt file in the buienradar folder to 8.3.3. That will stop the autoupdates.
Postby Toonz » Thu Mar 15, 2018 9:59 am
Version 8.3.4 released on ToonStore.
Changelog:
- EU radarmap option added to the big radarscreen
- version numbering of 8.3.3 was incorrect causing ToonStore to update the app daily when the auto-update feature of ToonStore was switched on
Kind regardz,
Postby globegrabber » Thu Mar 15, 2018 8:54 pm
Thx for adding the EU map in the app, Great work :D
Globegrabber.
globegrabber
Postby ronalddehaan » Mon Mar 19, 2018 8:59 am
Toonz wrote:Hi all,
Changelog:
Kind regardz,
Wow, great that you found the cause and released an update so quick! Good stuff! I will update the app when i get home :)
ronalddehaan
Postby Rudolf » Wed Mar 28, 2018 10:05 am
I can't install this app anymore. I used to have it installed, but I disabled it in Globals.xml to debug memory issues / spontaneous reboots.
I've tried reenabling and updating via ToonStore, but it doesn't work.
I can select 8.3.4 for installation and that seems to work (a download starts in the background and the gui restarts afterwards)
There's nothing installed in /qmf/qml/apps and Globals.xml doesn't have an entry to load buienrader.
ToonStore is fully updated (1.1.4) and my Toon is at 4.9.23.
Other apps I had disabled in the past work fine (boilerstatus/afvalwijzer etc.)
Where can I find ToonStore's logging to dig into this issue?
Rudolf
Postby Toonz » Wed Mar 28, 2018 11:36 am
Hi Rudolf,
log file can be found here: /mnt/data/update/_opkg.qb2-ene-9.9.99.script.sh.log.
It should show error messages or something like 'nothing to do'.
I guess the latter is the case because I suspect you haven't really uninstalled buienradar, but merely disabled it.
The install script thinks the app is still installed and therefore decides to do nothing.
In this case the best way forward is to properly uninstall first with:
opkg remove buienradar
and then reinstall again via ToonStore.
Kind regardz,
Postby Rudolf » Wed Mar 28, 2018 12:27 pm
Thanks for pointing me to that logfile, that's very helpful.
I tried removing buienrader via opkg, but it's not installed.
eneco-:/mnt/data/update# opkg remove buienradar
No packages removed.
list-installed doesn't list it either
eneco-:/mnt/data/update# opkg list-installed
base-files - 3.0.14-r100
base-passwd - 3.5.20-r1
base-qb2-ene - 4.9.23-1183-1
boilerstatus - 1.0.3-r0
boot-logos - 1.71
busybox - 1.27.2-r1
busybox-mountall - 1.27.2-r1
busybox-syslog - 1.27.2-r1
ca-certificates - 20160104-r1
chrony - 1.27-r1
cron - 3.0pl1-r8
curl - 7.50.0-r0
directfb - 1.2.8-r1.0
dropbear - 2015.71-r0
fileinfo - 1.0.6-r0
firmware-ba - 1.44
firmware-ma - 1.113-master
firmware-zwave-ctrlr - 1.8-4.55-NrNfNm-noeep
flash-gui - 1.651-ene-qeio
flash-lite-adobe - 4.0.3-54-fb0
flash-qwidget-diy - 1.161-qeio
freetype - 2.4.3-r1
glibc - 2.10.1-r37.1
glibc-binary-localedata-de-de - 2.10.1-r37.1
glibc-binary-localedata-en-gb - 2.10.1-r37.1
glibc-binary-localedata-en-us - 2.10.1-r37.1
glibc-binary-localedata-es-es - 2.10.1-r37.1
glibc-binary-localedata-fr-fr - 2.10.1-r37.1
glibc-binary-localedata-it-it - 2.10.1-r37.1
glibc-binary-localedata-nl-nl - 2.10.1-r37.1
glibc-gconv - 2.10.1-r37.1
glibc-gconv-iso8859-1 - 2.10.1-r37.1
glibc-localedata-i18n - 2.10.1-r37.1
glibc-localedata-iso14651-t1 - 2.10.1-r37.1
glibc-localedata-iso14651-t1-common - 2.10.1-r37.1
glibc-localedata-translit-circle - 2.10.1-r37.1
glibc-localedata-translit-cjk-compat - 2.10.1-r37.1
glibc-localedata-translit-compat - 2.10.1-r37.1
glibc-localedata-translit-font - 2.10.1-r37.1
glibc-localedata-translit-fraction - 2.10.1-r37.1
glibc-localedata-translit-narrow - 2.10.1-r37.1
glibc-localedata-translit-neutral - 2.10.1-r37.1
glibc-localedata-translit-small - 2.10.1-r37.1
glibc-localedata-translit-wide - 2.10.1-r37.1
glibc-patch-dns - 2.10.1-r37.2
gnupg - 1.4.10-r3
gnutls - 2.10.4-r11.0
gpgme - 1.1.4-r5
gpgv - 1.4.10-r3
happ-eventmgr - 1.203-master
happ-kpi - 1.397-master
happ-pwrusage - 1.665-ene-master
happ-scsync - 1.253-ene-master
happ-smartplug - 1.196-master
happ-thermstat - 1.1889-ene-fix-WTF-943-hotfix-add-rcm-rc-properly
happ-usermsg - 1.78-master
happ-weather - 1.137-master
hcb-bxtproxy - 1.347-master
hcb-comm - 1.179-N-master
hcb-config - 1.325-master
hcb-log - 1.72-master
hcb-netcon - 1.327-master
hcb-rrd - 2.153-master
hcb-watchdog - 1.60-master
hdrv-hue - 1.204-master
hdrv-p1 - 1.707-ene-master
hdrv-zwave - 1.1221-master
i2c-tools - 3.0.3-r0
initscripts - 1.2-r6-runlvls
iptables - 1.4.9.1-r7.1
jansson - 1.3-r1.0
joe - 3.1-r3
jpeg - 8b-r1
kernel - 2.6.36-R10-h27
kernel-image - 2.6.36-R10-h27
kernel-module-fat - 2.6.36-R10-h27
kernel-module-ftdi-sio - 2.6.36-R10-h27
kernel-module-msdos - 2.6.36-R10-h27
kernel-module-pl2303 - 2.6.36-R10-h27
kernel-module-rt5370sta - 2.6.36-R10-h27
kernel-module-rt5370sta-cfg - 2.6.36-R10-h27
kernel-module-rtl8191su - 2.6.36-R10-h27
kernel-module-vfat - 2.6.36-R10-h27
kernel-module-zwave300 - 2.6.36-R10-h27
less - 436-r1
libbz2 - 1.0.6-r0
libcrypto - 0.9.8m-r14.1
libcrypto1.0.0 - 1.0.2h-r2
libcurl - 7.50.0-r0
libgcc - 4.5-r33.1+svnr170443
libgcrypt - 1.4.1-r0
libgpg-error - 1.4-r7.1
libhcb-base - 1.287-master
libhcb-boxtalk - 1.117-master
libhcb-com - 1.118-N-master
libhcb-drv - 1.336-master
libhcb-xml - 1.102-master
libjansson4 - 2.10-r1.0
libnetfilter-conntrack - 0.0.101-r0
libnfnetlink - 1.0.0-r0.0
libopkg - 0.1.8+svns635-r7-gcv
libpng12 - 1.2.44-r3.0
libssl - 0.9.8m-r14.1
libssl1.0.0 - 1.0.2h-r2
libstdc++ - 4.5-r33.1+svnr170443
libsysfs - 2.1.0-r3
libuuid - 2.18-r36.0
lighttpd - 1.4.33-28
lighttpd-mod-hcb-web - 1.4.33-26
locale-base-de-de - 2.10.1-r37.1
locale-base-en-gb - 2.10.1-r37.1
locale-base-en-us - 2.10.1-r37.1
locale-base-es-es - 2.10.1-r37.1
locale-base-fr-fr - 2.10.1-r37.1
locale-base-it-it - 2.10.1-r37.1
locale-base-nl-nl - 2.10.1-r37.1
lzo - 1.08-r15
makedevs - 1.0.0-r10
module-init-tools - 3.12-r6
module-init-tools-depmod - 3.12-r6
modutils-initscripts - 1.0-r3
mtd-utils - 1.4.1-r0
ncurses - 5.7+20110115-r16
ncurses-libncurses - 5.7+20110115-r16
ncurses-libtinfo - 5.7+20110115-r16
ncurses-terminfo - 5.7+20110115-r16
ncurses-terminfo-base - 5.7+20110115-r16
netbase - 4.21-r50
openssh-sftp-server - 7.3p1-r10.0
openssl - 1.0.2h-r3
openssl-conf - 1.0.2h-r3
openvpn - 2.3.11-r1
opkg-collateral - 1.0-r3
pointercal - 0.0-r22
pth - 2.0.2-r2
qmf-0 - 1.19-master-r0
qt-gui - 1.7978-ene-hotfix-4.9
qt-libs - 5.3.1-06-setpos
readline - 5.2-r8
samba-nmbd - 3.0.20-r8
sysvinit - 2.86-r63
sysvinit-inittab - 2.86-r63
sysvinit-pidof - 2.86-r63
sysvinit-utils - 2.86-r63
toonstore - 1.1.4-r0
tsc-certificates - 1.0.1-r0
tslib - 1.0-r28.7hae
tslib-calibrate - 1.0-r28.7hae
tslib-conf - 1.0-r28.7hae
tzdata-americas - 2011b-r8.0
tzdata-europe - 2011b-r8.0
update-modules - 1.0-r10
update-rc.d - 0.7-r2
wastecollection - 3.5-r0
wget - 1.12-r8.3
wireless-tools - 29-r5
wpa-supplicant - 2.6-r0
wpa-supplicant-cli - 2.6-r0
wpa-supplicant-passphrase - 2.6-r0
www-jquery-ui - 1.8.21-16
www-resources - 1.35-master
x11vnc - 0.9.13-r0
zlib - 1.2.3-r7.0
Yet it seems to think it is installed, because it tries to backup some files.
/mnt/data/update/_opkg.qb2-ene-9.9.99.script.sh: line 568: echo>> dependencies found: tsc-certificates-1.0.0: not found
src/gz tsc2 http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.0
>> configured opkg feeds:
src/gz tsc1 http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.3.4
>> opkg update
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.3.4/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.3.4/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc1.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.3.4/Packages.sig.
Signature check passed.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.0/Packages.gz.
Inflating http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.0/Packages.gz.
Updated list of available packages in /var/lib/opkg/tsc2.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/../pkgs/tsc-certificates-1.0.0/Packages.sig.
>> Package cache: /mnt/data/update
>> opkg --cache /mnt/data/update install --download-only buienradar
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/buienradar-8.3.4/buienradar_8.3.4-r0_qb2.ipk.
>> opkg --cache /mnt/data/update install --download-only tsc-certificates
Package tsc-certificates (1.0.1-r0) installed in root is up to date.
>> downloaded:
52.0K   total
>> dropboxMessage buienradar-8.3.4BRBRBekijk de berichten voor deze software voor informatie over eventuele configuratie.
>> no packages to be removed
>> 2018-03-28 11:04:48 +0200 (pid 21582), status = prepared
>> 2018-03-28 11:04:52 +0200 (pid 21738), status = execute
>> 2018-03-28 11:04:52 +0200 (pid 21738), status = executing
>> opkg --cache /mnt/data/update install tsc-certificates
>> opkg --cache /mnt/data/update install buienradar
Installing buienradar (8.3.4-r0) to root...
Copying /mnt/data/update/buienradar_8.3.4-r0_qb2.ipk.
Running preinstall for buienradar-8.3.4
Older installation detected.
Backing up previous settings ...
mv: can't rename '/HCBv2/qml/apps/buienradar/selected*.txt': No such file or directory
Collected errors:
* pkg_run_script: package "buienradar" preinst script returned status 1.
* preinst_configure: Aborting installation of buienradar.
* opkg_install_cmd: Cannot install package buienradar.
>> deleting /tmp/dependencies_to_install.txt
>> deleting /tmp/packages_to_install.txt
>> reinstating cache handling (default 0)
I'll create a dummy file that matches that wildcard to see if it proceeds.
Rudolf
Postby Toonz » Wed Mar 28, 2018 2:15 pm
Ah, seems a bug in the install script (failing if no config data is present).
Can you manually create a file 'selectedStation.txt' in the buienradar folder and try again?
Postby Rudolf » Wed Mar 28, 2018 8:47 pm
Thanks for the suggestion.
I believe I tried that. (not 100% sure it was in the first attempt in the log below)
First I created a file called selectedzip.txt, lateron I added
selectedLongitude.txt selectedLatitude.txt and selectedStation.txt
But that didn't help, buienradar shows as installed, but I can't add its tile, and it doesn't list a version in ToonStore.
I tried removing it twice, but that fails when there's no *.ipk-file to remove.
(Even with a dummy .ipk-file in that folder)
What makes the ToonStore think that the app is still installed? Is it the buienradar-folder in /qmf/qml/apps?
I'm quite familiar with bash/linux, so if you can point me to the location of the script I can dig into it myself.
Or should I get rid of all apps and reinstall ToonStore?
>> Welcome to the ToonStore updater,
>> brought to you by the Toonroot Software Collective (TSC)
>> 2018-03-28 11:04:35 +0200 (pid 21582) _opkg.qb2-ene-9.9.99.script.sh qb2 ene 9.9.99 prepare
>> 2018-03-28 11:04:35 +0200 (pid 21582), status = preparing
>> Firmware version: 4.9.23, build 1183, rev 1.
>> System load     : 0.96
>> Free RAM        : 4540K
>> Flushing file system buffers and cache ...
>> Free RAM now    : 7384K
>> Hotfix for writing System Time to RTC
Hardware Clock before: Wed Mar 28 09:04:37 2018  0.000000 seconds
Hardware Clock after : Wed Mar 28 09:04:38 2018  0.000000 seconds
>> Installing buienradar-8.3.4
>> Extracting packages from the following repo('s):
>> opkg update
>> downloaded:
52.0K   total
Collected errors:
>> deleting /tmp/install_status
>> deleting all in /mnt/data/update
>> (this may give some errors, no problem here ...)
>> 2018-03-28 11:04:56 +0200 (pid 21738), status = executed
>> Restarting qt-gui and hcb_config ...
>> 2018-03-28 13:27:48 +0200 (pid 853), status = prepare
>> 2018-03-28 13:27:48 +0200 (pid 853) _opkg.qb2-ene-9.9.99.script.sh qb2 ene 9.9.99 prepare
>> 2018-03-28 13:27:48 +0200 (pid 853), status = preparing
>> System load     : 1.25
>> Free RAM        : 2524K
>> Free RAM now    : 7320K
Hardware Clock before: Wed Mar 28 11:27:52 2018  0.000000 seconds
Hardware Clock after : Wed Mar 28 11:27:52 2018  0.000000 seconds
>> opkg update
>> downloaded:
52.0K   total
>> 2018-03-28 13:27:59 +0200 (pid 853), status = prepared
>> 2018-03-28 13:28:02 +0200 (pid 1073), status = execute
>> 2018-03-28 13:28:02 +0200 (pid 1073), status = executing
Collected errors:
>> 2018-03-28 13:28:05 +0200 (pid 1073), status = executed
>> 2018-03-28 13:33:59 +0200 (pid 1735), status = prepare
>> 2018-03-28 13:33:59 +0200 (pid 1735) _opkg.qb2-ene-9.9.99.script.sh qb2 ene 9.9.99 prepare
>> 2018-03-28 13:33:59 +0200 (pid 1735), status = preparing
>> System load     : 1.02
>> Free RAM        : 3008K
>> Free RAM now    : 6388K
Hardware Clock before: Wed Mar 28 11:34:00 2018  0.000000 seconds
Hardware Clock after : Wed Mar 28 11:34:01 2018  0.000000 seconds
>> no packages to be installed
>> Removing buienradar-8.3.4
>> 2018-03-28 13:34:03 +0200 (pid 1735), status = prepared
>> 2018-03-28 13:34:06 +0200 (pid 1842), status = execute
>> 2018-03-28 13:34:06 +0200 (pid 1842), status = executing
>> deleting /tmp/packages_to_delete.txt
rm: can't remove '/mnt/data/update/*.ipk': No such file or directory
>> 2018-03-28 13:34:06 +0200 (pid 1842), status = executed
>> 2018-03-28 14:02:25 +0200 (pid 4301), status = prepare
>> 2018-03-28 14:02:25 +0200 (pid 4301) _opkg.qb2-ene-9.9.99.script.sh qb2 ene 9.9.99 prepare
>> 2018-03-28 14:02:25 +0200 (pid 4301), status = preparing
>> System load     : 1.12
>> Free RAM        : 5088K
>> Free RAM now    : 8140K
Hardware Clock before: Wed Mar 28 12:02:27 2018  0.000000 seconds
Hardware Clock after : Wed Mar 28 12:02:28 2018  0.000000 seconds
rm: can't remove '/var/lib/opkg/tsc*': No such file or directory
>> 2018-03-28 14:02:31 +0200 (pid 4301), status = prepared
>> 2018-03-28 14:02:33 +0200 (pid 4418), status = execute
>> 2018-03-28 14:02:33 +0200 (pid 4418), status = executing
>> 2018-03-28 14:02:33 +0200 (pid 4418), status = executed
Rudolf
Postby marcelr » Wed Mar 28, 2018 10:38 pm
The installer installs the app in /qmf/qml/apps/<app-name>-<app-version>, creates a symlink to this directory and stores the control file and pre- and postinstaller (if present) in /usr/lib/opkg/info/
So, simply removing the app does not convince the package manager that you actually removed it. You will need to get rid of the opkg-related parts as well, and that is best achieved by opkg remove <app-name>.
If that fails (e.g., because you removed the app manually, with rm and the likes), the opkg-related stuff remains where it is.
Postby Rudolf » Thu Mar 29, 2018 7:03 am
It seems that there's still some stuff in /usr/lib/opkg/status, it shows the following entries:
Package: buienradar
Version: 8.3.4-r0
Depends: tsc-certificates (>= 1.0.0)
Provides:
Status: install user not-installed
Architecture: qb2
Package: buienradar
Version: 8.3.3-r0
Provides:
Architecture: qb2
But this is not the data that is used by ToonStore, ToonStore checks for the existence of the folder in 'qmf/qml/apps/'
If I understand the code below correctly:
        function getInstalledStatus() {
                var findMinus = folder.indexOf("-");
                if (findMinus > 0) {
                        folderStripped = folder.substring(0, findMinus);
                } else {
                        folderStripped = folder;
                return (app.installedApps.indexOf(folderStripped) > 0 );
        function getInstalledVersion() {
                } else {
                var versionStr = appVersionTxt.read();
                return versionStr.trim();
Removing that folder allowed me to reinstall again. And the logs looks good.
Yet there's another issue, ToonStore lists two versions of 'WasteCollection', 3.5/3.6 and 3.6/3.6, both installed. But that's not something for this thread. :lol:
Thanks for the hints, I can finally enjoy buienradar on my Toon again. :D
Rudolf
Postby Toonz » Thu Mar 29, 2018 8:34 am
Rudolf wrote:Yet there's another issue, ToonStore lists two versions of 'WasteCollection', 3.5/3.6 and 3.6/3.6, both installed. But that's not something for this thread. :lol:
This is my error, I forgot to remove the old entry of wastecollection in the repository when creating the new one (fixed now, just refresh the ToonStore data to remove the double entry)
Thanks for the tip.
Postby jnieuw » Wed Apr 18, 2018 8:09 am
So somehow after a reboot the Buienradar app cannot contact https://xml.buienradar.nl anymore.
Wget gives this:
eneco-001-097000:~# wget https://xml.buienradar.nl/
--2018-04-18 06:59:25--  https://xml.buienradar.nl/
Resolving xml.buienradar.nl... 104.93.83.81, 104.93.83.24, 2a02:26f0:fe:29d::5ddd, ...
Connecting to xml.buienradar.nl|104.93.83.81|:443... connected.
OpenSSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
Unable to establish SSL connection.
With curl I can download the xml file.
eneco-001-097000:~# curl https://xml.buienradar.nl
<buienradarnl>
  <weergegevens>
    <titel>www.buienradar.nl - actuele weersinformatie</titel>
    <link>http://www.buienradar.nl</link>
    <omschrijving>Publieke weersinformatie feed</omschrijving>
    <language>nl-nl</language>
    <copyright>(C)opyright 2005 - 2018 Buienradar B.V. Alle rechten voorbehouden</copyright>
    <gebruik>Deze feed mag vrij worden gebruikt onder voorwaarde van bronvermelding buienradar.nl inclusief een hyperlink naar https://www.buienradar.nl. Aan de feed kunnen door gebruikers of andere personen geen rechten worden ontleend.</gebruik>
    <image>
  </weergegevens>
</buienradarnl>
Already reinstalled tsc-certificates_1.0.1-r0_qb2.zip
The "regenverwachting" tile shows me the correct location and when I change it the image of google maps changes properly.
I cannot select a "Weerstation" because the xml cannot be loaded.
Does anyone have an idea? (Firmware 4.15.2)
jnieuw
Postby Toonz » Wed Apr 18, 2018 8:12 am
jnieuw wrote:Does anyone have an idea? (Firmware 4.15.2)
This firmware is not officially released, haven't tested it myself. But I suspect an issue with your SSL certificates, see my other post in the Afvalwijzertopic
Postby jnieuw » Wed Apr 18, 2018 11:08 am
Hi Toonz,
Like I said, I already reinstalled the tsc-certificates_1.0.1-r0_qb2.zip, but that did not fix it.
How can I check is tsc-certificates is installed correctly?
jnieuw
PreviousNext
Return to Toon Apps
