Page 20 of 22
Re: Toon app: Buienradar
Posted: Sat Feb 27, 2021 10:54 am
by Blacky's Boss
Updated and tested. Working again. Thanks!!!!
Posted: Sat Feb 27, 2021 1:21 pm
by Arnout2000
Thanks for the update!
Posted: Sun Feb 28, 2021 3:59 pm
by flow
Just this morning I noticed buienradar didn't work, and it has already been fixed. Thanks!
Posted: Thu Apr 08, 2021 11:23 am
by Arnout2000
Since today the Buienradar temperature shows NaN °C.
Have they changed anything in the format?
Posted: Thu Apr 08, 2021 11:38 am
by Ron_nl
No problem here, maybe your (chosen) weather station is down.
Ron.
Posted: Thu Apr 08, 2021 11:46 am
by Arnout2000
You might be right. It seems to be right again.
the image below is what I had earlier.....
Posted: Fri Oct 08, 2021 3:44 pm
by Toonz
version 9.0.2 is available in the ToonStore.
It is a complete rewrite of the application.
I now use the new JSON data feed from buienradar (
https://data.buienradar.nl/2.0/feed/json) instead of the old XML file (
https://data.buienradar.nl/1.0/feed/xml)
The JSON file seems to be more reliable and is much easier to process (40% less lines of code needed).
Compared to the old version 8.5.13 no new functionality has been added, one small bug has been removed in the location screen.
The top half of the detail screen layout has some cosmetic improvements.
Kind regards,
Posted: Fri Oct 08, 2021 8:46 pm
by Arnout2000
That is great!
Thank you for the update. Looks good!
Posted: Mon Feb 21, 2022 7:10 pm
by Toonz
version 9.0.3 is available in the ToonStore.
Changelog: a new tile has been added to show sunrise and sunset times for the day
Posted: Sun Feb 27, 2022 8:23 pm
by MarieJo
I have a rooted toon (boxx from Engie in Belgium) and Installed buienradar. But many options like pollenradar, muggenradar , show only the Nederlands as a country. Is it possible to add Belgium and the wether stations of Belgium?
Posted: Sun Feb 27, 2022 9:46 pm
by Toonz
I just had a look, I can indeed show the radar images from buienradar.be (funny enough these are hosted at the buienradar.nl server but that aside).
For the rest the app needs to be rebuild completely (= new BE app) as buienradar.be is not supplying the JSON file with all weather stations as for NL which is the foundation for the current app.
Will see what I can do coming week.....
EDIT: had a closer look and can easily implement the city selection process from buienradar.be.
All weather details need to be scraped from the webpage, little bit of work but expect a "Buienradar Belgium" app in the ToonStore at some point in the future (no commitment on a specific release date
Posted: Mon Feb 28, 2022 9:12 am
by MarieJo
Thanks Toonz. That”s great! The biggest and most important wether station in Belgium is Ukkel, nervy Bruxelles and where I live. I’m thrilled and excited too see the result. Especially the pollenradar will be of great help here. I hope to hear from you soon.
Posted: Mon Feb 28, 2022 3:39 pm
by Toonz
Hi MarieJo,
I noticed that the weather data in Belgium is not refreshed very often (at 14:35 still showing data from 13:00) compared to the NL weather stations which are updated every 10-20 minutes.
Anyway, better then nothing. I started today, by far not finished but a quick preview of the work-in-progress below as a teaser
EDIT: at 14.41 the data was updated with the weatherstation data at 14:00)
Regardz,
- BuienraderEurope1.png (59.66 KiB) Viewed 3272 times
- BuienraderEurope2.png (120.14 KiB) Viewed 3272 times
Posted: Mon Feb 28, 2022 6:17 pm
by MarieJo
Awesome! Thank you very Much!
Posted: Thu Mar 03, 2022 10:33 am
by Toonz
Hi MarieJo,
I've completed the initial release of the new "EU Buienradar" app, it will be available in the ToonStore soonish.
I will post more details in a new topic for this app when it is available.
