Page 3 of 4
Re: Toon app: Traffic information
Posted: Mon Oct 14, 2019 9:37 am
by Xavier
ok, will wait on the new app
Posted: Mon Oct 14, 2019 9:43 am
by Toonz
just checked the anwb json feed but the actual speed radar info is not included (although the JSON file suggests it would).
Anyway, the app is working fine again on a Toon 2, need to polish it a bit and do tests on a toon 1 for performance and layout.
This new release will become available in the ToonStore in the near future.
Posted: Mon Oct 14, 2019 5:39 pm
by Xavier
still not able to install.
Keeps telling:
"Deze applicatie Verkeersinformatie is niet geschikt voor de software versie 5.13.12 van uw Toon"......
Posted: Mon Oct 14, 2019 7:00 pm
by Toonz
Xavier wrote:still not able to install.
Keeps telling:
I am quick but not that quick.
Again: you get this message because I blocked installation of the old app via the ToonStore on all firmwares because it absolutely doesn't make sense to install it as it will not receive any traffic data.
The new version of the app is currently being developed, as you can read in my post above yours:
"When the new app is completed it will be available through the ToonStore again"
Please forget about version 1.0.9, it is obsolete.
I will post it here when the new app is available, as usual it will get a higher version number.
Posted: Mon Oct 14, 2019 7:07 pm
by Xavier
ahhhhhhhhhhhhhhhhhh I misunderstood you.
Sorry about that!
Posted: Thu Oct 17, 2019 3:20 pm
by Toonz
the brand new version 2.0.0 is available in the ToonStore.
It uses the new json feed from anwb.nl.
Only available for firmware version 5.x.x
Changelog 2.0.0:
- changed the source from xml.fileindex.nl to the anwb.nl json feed
- user settings (road filter) are now stored in the persistent /mnt/data/tsc folder
- this update will only be available on firmware 5 Toons
Posted: Thu Oct 17, 2019 11:02 pm
by Xavier
Thanks, great Job.
Already installed it
Posted: Fri Jan 10, 2020 10:44 pm
by aabre
Hi Toonz,
great that the trafic info app is working again, I only have a small question, in the early version I had in the road filter only A13 and A20 and when there was no traffic jam the tile was empty, now I see all the other roads also, even with filter on or off.
Is there something I can do about this ?
Many thanks for the new 2.0.0 version
Posted: Sat Jan 11, 2020 4:02 pm
by Toonz
aabre wrote:Hi Toonz,
No, it's a bug, will fix it in the next release
Posted: Sat Jan 11, 2020 4:49 pm
by Toonz
version 2.0.1 is available in the ToonStore.
Changelog:
- the road filter is now also correctly applied to the tile
Posted: Sat Jan 11, 2020 7:17 pm
by aabre
Great job !!
Many thank's Toonz it's working like a charm
Verkeersinformatie
Posted: Fri May 01, 2020 10:04 am
by jumperone
Geen verkeersinformatie meer.
melding:Verkeersinformatie ophalen mislukt.geen internet verbinding.
Wel internet verbinding. Andere apps werken voor 100%
software 5.25.8
Re: Verkeersinformatie
Posted: Fri May 01, 2020 10:28 am
by TerrorSource
jumperone wrote:Geen verkeersinformatie meer.
software 5.25.8
I've moved your post to the corresponding "Verkeersinformatie" topic.
Posted: Fri May 01, 2020 2:02 pm
by Toonz
the error message is a bit misleading maybe. Point is that the app could not retrieve the latest traffic data. It can be because of a local WiFi/internet issue or an issue with at the data provider. Anyway, should resolve automatically when the underlying issues has been resolved.
Posted: Wed May 13, 2020 9:53 am
by jumperone
De link van ANWB:
https://www.anwb.nl/feeds/gethf
volgens ANWB bestaat niet meer.
Dus weet ik het ook niet meer
