Toon app: ToonStore
Re: Toon app: ToonStore
Postby Toonz » Sun May 31, 2020 9:11 am
version 5.0.8 is available in the ToonStore.
This version is preparing for the arrival of applications which will run on a Toon 2 only due to the limited hardware capabilities of Toon 1.
In case an app is not compatible with your Toon, the install button is replaced by an exclamation sign. When you press it, it shows the reason why the app can't be installed.
Changelog:
- ability to block specific app installation on old Toons when designed for Toon 2 only.
- change in background color for apps which can't be installed on your toon because
either the firmware version is too low or the app is not compatible with the old model Toon
Postby Toonz » Mon Jun 08, 2020 11:16 am
version 5.0.9 is available in the ToonStore.
Changelog:
- notifications of new app versions are not shown anymore when auto updating of apps is switched on
Previous
Return to Toon Apps
