Toon app: Sonos Control
Re: Toon app: Sonos Control
Postby Toonz » Sat Sep 29, 2018 9:36 am
The original author isn't very active anymore. I can update the app for the new screen resolution of Toon 2, but don't have Sonos kit myself, so cannot do proper functional testing.
Postby TheHogNL » Sat Sep 29, 2018 12:05 pm
dennis071nl wrote:Hi guys,
Any plans to update the Sonos player for the TOON 2???
Dennis
Maybe try it yourself :) It is not that hard. And as Toonz said you need someone with sonos gear to test all functions.
Postby dennis071nl » Sat Sep 29, 2018 7:29 pm
Dennis
is there something like a tutorial foor n00bs? :-) no experience at all with programming, but i'm a fast learner and prepared to contribute to the community..!
dennis071nl
Postby Toonz » Sat Sep 29, 2018 8:40 pm
Super quick first hint.
The screen resolution of Toon 2 is 1024 x 800, Toon 1 is 800 x 600.
meaning that you have to multiply the x-coordinates of screen elements by 1,28 for Toon 2, y coordinate by 1,33 and font sizes by 1,3 ( roughly).
Either by using the Match formula or calculate the new coordinates yourself (I often use 1,25 easy to calculate by brain :-) )
Also replace all absolute values a formule to get correct display on both Toon 1 and Toon 2 by querying the isNxt (=Toon 2) variable.
Do this for all screen element positioning and sizing attributes in the qml files in the Sonos folder in qml/qmf/app/sonos
Example from MediaScreen.qml:
      anchors {
         top: labelContainer.bottom
         topMargin: 30
         left: parent.left
         leftMargin: 44
         right: parent.right
         rightMargin: 27
      spacing: 20
should become
      anchors {
         topMargin: isNxt ? 38 : 30
         left: parent.left
         leftMargin: isNxt ? 55 : 44
         right: parent.right
         rightMargin: isNxt ? 34 : 27
      spacing: isNxt ? 25 : 20
Do this for all screen elements in the qml files in the Sonos folder.
When you are happy with the result, send me the sonos folder in a zipfile so I can publish it in ToonStore.
Kind regardz,
Postby Toonz » Wed Jan 16, 2019 11:39 pm
version 1.0.4 is available in ToonStore.
Changelog:
-firmware 5 compatibility of the installer. No new functionality
Kind regardz,
Postby Toonz » Mon Jan 21, 2019 8:29 pm
version 1.0.5 is available in ToonStore.
Changelog:
- fixed a glitch in the installer which caused issues with the firmware upgrade script
- no new functionality
Kind regardz,
Postby SubSun » Thu Feb 14, 2019 8:55 am
Hi, i'm new here and have a quick question. I'm planning to root my Toon.
I would like to use it to control my Sonos system (and adjust temperature with smartphone).
After it is rooted, can i take the app from the Store by the wifi connection or do i need to connect it to my pc each time i want to add an app/update it to a new version? Wondering it, cause i need to know if i need to order the usb-to-serial-cable. If i need to have this for future use, i could try to root it myself. If not needed anymore then i will probably have someone to root it for me.
SubSun
Postby Toonz » Thu Feb 14, 2019 9:35 am
After rooting, the app on Toon communicates directly with the SONOS system via Wifi.
App updates will come via the ToonStore on Toon.
No need for the rooting kit after rooting
Postby sil » Wed Feb 20, 2019 9:26 pm
Toon communicates not with the SONOS system via Wifi.
What ip do i use an what portnumber does sonos used.
In my router i can find hostname SonosZB an SonosSB
Need help to fix this problem
sil
Postby Klendy » Sat Mar 02, 2019 10:29 pm
Same problem here. Which ip adres and poort number? Where can i find that. Ip adres from sonos is not working.
Can someone help us?
Klendy
Postby RobbieT » Sun Mar 10, 2019 7:37 pm
legalr wrote:Tried this app to controll the my sonos.
Installed the Sonos Http API on my Synolgy nas (docker container)
controlling the Sonos is possible, and favorite list is availiable.
but not all vissual functions are working on FW 4.19, is there going to be an update?
Hi!
I want to install the api in a docker container on my synology. Can you help me out how you made this work?
Edit:
Nevermind; got it to work :-)
RobbieT
Postby yustmenl » Sun Jun 02, 2019 9:54 am
Thanks for this great app i realy like it.
The only thing that i am missing is an option to browse the media library, is this planned? Or how have you guys solved this?
yustmenl
Postby TerrorSource » Mon Jun 03, 2019 9:32 am
yustmenl wrote:Thanks for this great app i realy like it.
This app is no longer improved/developed.
Maker of this app sold this Toon and stopped developing.
TerrorSource
Postby mAiden » Mon Jun 03, 2019 11:13 am
Like Terrorsource said, creator has stopped making this app..
I just want to see if I can build it in for you this weekend, but I don't have any sonos, I can't test it.
mAiden
Postby yustmenl » Tue Jun 04, 2019 12:54 pm
mAiden wrote:Like Terrorsource said, creator has stopped making this app..
If you like to do it would appreciate it and i can test it.
Hopefully a lot of other users can also benefit from that feature.
yustmenl
PreviousNext
Return to Toon Apps
