House-energy wrote:Hello,
Can anyone tell me how to enter the "SpotEnergy" settings
Domoticz has to make?
Create a virtual sensor in domoticz of type 'alert'. Then point the spotenergy setting to the domoticz server and the IDX of that created sensor.
From then on the Toon will update that alert sensor with green,yellow or red status (depening on low medium or high tariff) and will also put the tariff itself in the data field of the sensor.
Next you can trigger, within domoticz, other tasks depending on that status. For example, I use that to heat my boiler only if the tariff is 'green' (low).
