Toon app: Dashticz (no longer working)
Re: Toon app: Dashticz (for Toon); NEW: OV Info (NL)
Postby atlantica » Thu Feb 21, 2019 1:46 pm
What editor do you use? Try to use vi for editing...
Regards
David
atlantica
Postby mAiden » Thu Feb 21, 2019 1:49 pm
atlantica wrote:What editor do you use? Try to use vi for editing...
Dont like vi, i have always a fight with it.. I use WinSCP on Windows, you can edit also with it. Or i use nano on Linux to edit, Toon dont have nano onboard. :)
mAiden
Postby richardklasens » Fri Feb 22, 2019 9:34 pm
I tried to install today on my freshly Rooted toon.
SW 5.0.4.
Edited the DomoticzBoardApp.qml for my IDX numbers.
Then send it thru my toon with SFTP.
Rebooted
I have a Lightbulb on the tray... Check
When i opened the Domoticz screen on Toon i have 8 Grayed Squares without png's or names.
The grayed squares are connected to my IDX numbers and they work.
So only the Visual section isn't working.
I've checked a few lines of code in DomoticzBoardApp.qml and find out that the names of the PNG files don't match with the png's in the Drawables folder?
Any solutions?
richardklasens
Postby RobbieT » Mon Mar 11, 2019 5:24 pm
richardklasens wrote:I tried to install today on my freshly Rooted toon.
SW 5.0.4.
Rebooted
Any solutions?
I got this problem to but find out that i actually used a wrong username/password. Can you tell me what your domoticz log is showing? And did you converted the username and password to base64?
RobbieT
Postby mAiden » Wed Mar 13, 2019 10:15 am
You need to wait for the next update, pngs and images are not in the resourcefile now..
mAiden
Postby phoenixb » Wed Aug 14, 2019 12:20 am
Because the DomoticzBoard and Dashticz app is both writed in this topic I want to know if the Dashticz app is still working in the latest Toon version?
__________________
phoenixb
Postby Hypermobile » Sun Sep 08, 2019 6:25 pm
Dashticz: Nope not available anymore in 5.13.9 :-(
@least i don't see the icon anymore on the top...
switching to domoticzboard...but the amount of switches is limited
Hypermobile
Postby Blacky's Boss » Thu Sep 12, 2019 11:55 am
Yes, but you are completely free to choose which switches you want. Dashticz only showed favorites. Can you guess what my favorites are?
Correct. All information from Toon... Makes a nice dashboard in the app.
Blacky's Boss
Postby ArieKanarie » Sat Sep 28, 2019 12:24 pm
Now that dashticz is not working properly, what is the right & complete way to remove the app from my toon, since it is not installed through the appstore/
ArieKanarie
Postby Toonz » Sat Sep 28, 2019 12:55 pm
ArieKanarie wrote:Now that dashticz is not working properly, what is the right & complete way to remove the app from my toon, since it is not installed through the appstore/
simply remove the folder dashticz from the folder /qmf/qml/apps
Postby ArieKanarie » Sat Sep 28, 2019 1:10 pm
That is easy :)
Thanks.
ArieKanarie
Postby retroscoot » Fri Oct 16, 2020 10:06 pm
hello,
is this working?
i got some trouble..
i have place it into the right map on the toon.
but i needed to edit this file '/HCBv2/qml/qb/base/Globals.qml' but i dont have that file...
got an rooted toon from markplaats. and new into it...
greetz
retroscoot
Postby mAiden » Sat Oct 17, 2020 9:55 pm
retroscoot wrote:hello,
is this working?
greetz
Dashticz will not work on the last version. You can't edit globals.qml anymore, this file is hidden in the resourcefile.
You can download DomoticzBoard.
mAiden
Postby TerrorSource » Sat Oct 17, 2020 10:45 pm
Topic closed due to inactivity from the developer while app is in need of an update.
Please send me a PM if you want to continue to develop this app
TerrorSource
Previous
Return to Toon Apps
