Toon app: Webcam
Re: Toon app: Webcam
Postby Toonz » Wed Jan 16, 2019 11:31 pm
hi all,
version 1.0.4 is available is available in ToonStore.
changelog:
- firmware 5 compatibility of the installer, no new functionality
Kind regardz,
Postby Xavier » Mon Jan 21, 2019 7:55 pm
Toonz wrote:hi all,
changelog:
Kind regardz,
Loading a cam makes Toon crash. Any one else with this issue?
Toon2 with 5.33.9 firmware TSC 2.1.1
Apps: Sonos, Calender, garbagecalender, traffic information, webcam, doorcam, PostNL, public transport, Onkyo, Domoticzboard and weather app.
Xavier
Postby TheHogNL » Mon Jan 21, 2019 8:00 pm
The default example webcam works ok at my toon1 with 5.0.4
Postby Xavier » Mon Jan 21, 2019 9:25 pm
ok, so now when I want to reinstall the webcam, I go to Toon store, remove webcam app, then "Toon bijwerken"
Toon reboots…
Toon comes back, I go to Toon store, reinstall the webcam app, then Toon again reboots (I see the downloadsign in the header) and then nothing happens.
webcam app isn't installed.
Viewen with CLI into apps folder I can't see a folder created for webcam....
Xavier
Postby Toonz » Mon Jan 21, 2019 9:56 pm
Xavier wrote:ok, so now when I want to reinstall the webcam, I go to Toon store, remove webcam app, then "Toon bijwerken"
Toon reboots…
what does the logfile say at the bottom: /mnt/data/update/_opkg.qb2-uni-9.9.99.script.sh.log ?
Postby Xavier » Mon Jan 21, 2019 10:53 pm
what does the logfile say at the bottom: /mnt/data/update/_opkg.qb2-uni-9.9.99.script.sh.log ?[/quote]
eneco-001-033034:/mnt/data/update# tail _opkg.qb2-uni-9.9.99.script.sh.log
>> opkg --cache /mnt/data/update install webcam
Package webcam (1.0.4-r0) installed in root is up to date.
>> deleting /tmp/packages_to_install.txt
>> reinstating cache handling (default 0)
>> deleting /tmp/install_status
>> deleting all in /mnt/data/update
>> (this may give some errors, no problem here ...)
rm: can't remove '/mnt/data/update/*.ipk': No such file or directory
>> 2019-01-21 21:14:21 +0100 (pid 10527), status = executed
>> Restarting qt-gui and hcb_config ...
Xavier
Postby Toonz » Mon Jan 21, 2019 11:02 pm
Toon thinks the webcam package is still installed.
Did you remove the webcam folder manually?
That is not the correct way to uninstall packages.
Go to the command prompt and enter:
opkg remove webcam
After that you can install again via ToonStore
Postby Xavier » Mon Jan 21, 2019 11:16 pm
Wow, thanks Toonz, I indeed removed it manually.
After opkg remove command reinstalled the webcam, app now working again.
But now when inserting my cam (Foscam) in WebcamApp.qml like:
http://ip-adres:port/cgi-bin/CGIProxy.f ... ampassword and saving the file via "WinSCP" Toon becomes unresponsive.
Whats the good way to edit htese files without Toon getting unresponsive?
Xavier
Postby Xavier » Mon Jan 21, 2019 11:18 pm
btw, webcam works now with image.
Xavier
Postby Toonz » Mon Jan 21, 2019 11:22 pm
ok, good to hear. I do not have a webcam myself, just tried the default webcam from the alps provided by the app.
The performance on Toon 1 with real-time video isn't overwhelming by the way ;-).
Postby menno000 » Fri Feb 01, 2019 10:18 am
Thank you for this app, i get is working but i have a couple questions
* Is it possible to see more than 1 webcam? i want to cycle true 4 webcams
* in the main screen i want to see real time, i now see the picture install the app it is not refreshing
is it possible to see the cam in realtime in the tile?
menno000
Postby hanplo » Sun Oct 27, 2019 1:21 pm
Did someone succeed to view a Dahua cam on the Toon. I need some help.
hanplo
Postby Toonz » Mon Nov 04, 2019 11:12 pm
a small maintenance release 1.0.5 has been published in the ToonStore.
Changelog:
- settings are now stored in the /mnt/data/tsc folder
- config screen edit function didn't work on the latest firmware(s)
- compatible with firmware 5 only, support for lower firmwares has been dropped
Kind regardz,
Postby Hanzenman » Sun Dec 29, 2019 11:30 am
Hi All,
I have a Hikvision camera, is there anyone who has linked this camera to the APP
Best regards, Hans
Hanzenman
Postby bartch » Sun Feb 16, 2020 10:22 am
i am trying to find the right jpg-stream from a Ski-resort to be displayed on my Toon..is this possible? the only thing i can find is: nl.bergfex.com/oberwiesenthal-fichtelbe ... ams/c7036/ but how do i find the jpg-stream from this?
bartch
PreviousNext
Return to Toon Apps
Users browsing this forum: Floris25 and 1 guest
