Toon app: Webcam
Re: Toon app: Webcam
Postby TerrorSource » Sun Feb 16, 2020 4:51 pm
Hanzenman wrote:Hi All,
I have a Hikvision camera, is there anyone who has linked this camera to the APP
Best regards, Hans
If you find the correct URL for the camera feed it should work.
bartch wrote:Hi,
i am trying to find the right jpg-stream from a Ski-resort to be displayed on my Toon..is this possible? the only thing i can find is: nl.bergfex.com/oberwiesenthal-fichtelbe ... ams/c7036/ but how do i find the jpg-stream from this?
Ask the one responsible for the feed if they have the correct URL for you. We cannot provide that for you.
TerrorSource
Postby newwolf » Sun Feb 16, 2020 8:00 pm
Hee,
This works for my hikvision camera. (with the newer firmware versions)
http://user:pass@ipaddress/ISAPI/Stream ... 01/picture
Greetz,
Jos
newwolf
Postby yustmenl » Sat May 23, 2020 1:21 pm
he guys,
I installed the app and added a cam but now Toon keeps rebooting.
I can ssh to it with a stable connection.
Any ideas on how to solve this?
Thanks!
Edit: looks like tha after 30 minutes of rebooting it came back into the GUI
yustmenl
Postby Rudolf » Sun Jun 28, 2020 5:09 pm
My hacked dafang cam doesn't provide a jpeg-url.
I managed to get it working via home assistant API:
https://url.duckdns.org:8123/api/camera ... hot?token=<token>
Works nicely.
Edit: Nevermind, that token is subject to change, so it stops working after some time.
Rudolf
Postby michel30 » Tue Jun 30, 2020 11:06 pm
When I want to used it, the stream is too high so it does not work on my Toon 1.
It was a good tip to try it with home assistant API....
michel30
Postby TerrorSource » Tue Jun 30, 2020 11:19 pm
Rudolf wrote:My hacked dafang cam doesn't provide a jpeg-url.
Works nicely.
I own a Dafang 1080p myself and hacked it with Xiaomi-Dafang-hacks ( https://github.com/EliasKotlyar/Xiaomi-Dafang-Hacks )
Have you tried: https://dafang/cgi-bin/currentpic.cgi ?
TerrorSource
Postby Rudolf » Thu Jul 02, 2020 8:52 am
I thought I'd tried that and failed, but it works now. Thnx.
Rudolf
Postby a3_rotterdam » Fri Nov 13, 2020 10:14 pm
Have played today with the webcam app and tried many addresses but till now not very successful.
The IP camera is a MOBOTIX D25. Connected at my own network.
Via Firefox or Chrome the following links are all working fine, sometimes the programs asks for the username/password conformation.
When i try it with Internet Explorer, it will not find the webpage only when i remove the username and password at the address line. It opens then the camera login page.
Have tried:
http://username:password@192.168.178.20 ... stream.jpg
http://username:password@192.168.178.20 ... full&fps=0
http://username:password@192.168.178.20 ... quality=10" encoding="mjpeg"
http://username:password@192.168.178.20 ... urrent.jpg
Is there anyone who have some ideas?
Best regards,
Adri
a3_rotterdam
Postby oepi-loepi » Tue Nov 17, 2020 1:09 am
a3_rotterdam wrote:Hello,
Have tried:
Best regards,
Adri
According to ispyconnect you have to try record/current.jpg?sync=-99. For this camera
oepi-loepi
Postby skadjea » Mon Dec 28, 2020 12:01 pm
I am not able to get this application to work.
My adres to the webcam (medion ipc-10Ac resulution: 640*320) is http://camadres/snapshot.jpg
The link is working on the pc, but not on the Toon.
What Am I doing wrong.
And is it also possible to make more cams active on the toon?
skadjea
Postby michel30 » Fri Jan 01, 2021 12:44 am
I think because the picture is to big in MBs for the Toon.
I had also the same problem.. I shows for a sec and the Toon stopped and reboot because the big size of the picture.
michel30
Postby Vriesfde » Wed Feb 24, 2021 10:59 am
Works nicely.
How did you get around the dafang authentication terrorsource? My dafangs require username/password when accessing the jpg preview page
I tried https://user:pass@dafang-ip/cgi-bin/currentpic.cgi
Works on a pc browser bu on the toon2 I get a blank
Vriesfde
Previous
Return to Toon Apps
cron
