Page 3 of 3
Re: Toon app: Webcam
Posted: Sun Feb 16, 2020 4:51 pm
by TerrorSource
Hanzenman wrote:Hi All,
I have a Hikvision camera, is there anyone who has linked this camera to the APP
Best regards, Hans
If you find the correct URL for the camera feed it should work.
Ask the one responsible for the feed if they have the correct URL for you. We cannot provide that for you.
Posted: Sun Feb 16, 2020 8:00 pm
by newwolf
Hee,
This works for my hikvision camera. (with the newer firmware versions)
http://user:pass@ipaddress/ISAPI/Stream ... 01/picture
Greetz,
Jos
Posted: Sat May 23, 2020 1:21 pm
by yustmenl
he guys,
I installed the app and added a cam but now Toon keeps rebooting.
I can ssh to it with a stable connection.
Any ideas on how to solve this?
Thanks!
Edit: looks like tha after 30 minutes of rebooting it came back into the GUI
Posted: Sun Jun 28, 2020 5:09 pm
by Rudolf
My hacked dafang cam doesn't provide a jpeg-url.
I managed to get it working via home assistant API:
https://url.duckdns.org:8123/api/camera ... ken=<token>
Works nicely.
Edit: Nevermind, that token is subject to change, so it stops working after some time.
Posted: Tue Jun 30, 2020 11:06 pm
by michel30
When I want to used it, the stream is too high so it does not work on my Toon 1.
It was a good tip to try it with home assistant API....
Posted: Tue Jun 30, 2020 11:19 pm
by TerrorSource
Rudolf wrote:My hacked dafang cam doesn't provide a jpeg-url.
Works nicely.
I own a Dafang 1080p myself and hacked it with Xiaomi-Dafang-hacks (
https://github.com/EliasKotlyar/Xiaomi-Dafang-Hacks )
Have you tried:
https://dafang/cgi-bin/currentpic.cgi ?
Posted: Thu Jul 02, 2020 8:52 am
by Rudolf
I thought I'd tried that and failed, but it works now. Thnx.
Posted: Fri Nov 13, 2020 10:14 pm
by a3_rotterdam
Have played today with the webcam app and tried many addresses but till now not very successful.
The IP camera is a MOBOTIX D25. Connected at my own network.
Via Firefox or Chrome the following links are
all working fine, sometimes the programs asks for the username/password conformation.
When i try it with Internet Explorer, it will not find the webpage only when i remove the username and password at the address line. It opens then the camera login page.
Have tried:
http://username:password@192.168.178.20 ... stream.jpg
http://username:password@192.168.178.20 ... full&fps=0
http://username:password@192.168.178.20 ... quality=10" encoding="mjpeg"
http://username:password@192.168.178.20 ... urrent.jpg
Is there anyone who have some ideas?
Best regards,
Adri
Posted: Tue Nov 17, 2020 1:09 am
by oepi-loepi
According to ispyconnect you have to try record/current.jpg?sync=-99. For this camera
Posted: Mon Dec 28, 2020 12:01 pm
by skadjea
I am not able to get this application to work.
My adres to the webcam (medion ipc-10Ac resulution: 640*320) is
http://camadres/snapshot.jpg
The link is working on the pc, but not on the Toon.
What Am I doing wrong.
And is it also possible to make more cams active on the toon?
Posted: Fri Jan 01, 2021 12:44 am
by michel30
I think because the picture is to big in MBs for the Toon.
I had also the same problem.. I shows for a sec and the Toon stopped and reboot because the big size of the picture.
Posted: Wed Feb 24, 2021 10:59 am
by Vriesfde
How did you get around the dafang authentication terrorsource? My dafangs require username/password when accessing the jpg preview page
I tried
https://user:pass@dafang-ip/cgi-bin/currentpic.cgi
Works on a pc browser bu on the toon2 I get a blank
Posted: Sun Aug 29, 2021 8:31 pm
by Daniel
hanplo wrote:Did someone succeed to view a Dahua cam on the Toon. I need some help.
I know it's a very old question, but for my Dahua this works:
http://admin:###password###@192.168.178 ... shot.cgi?1
###password### enter your own password here.
ip- change to your own cam
