Toon app: Kalender
Re: Toon app: Kalender
Can you try file:///.... (three slashes....). Haven't tried myself...
It does work! But with the wrong display of the birthdays.. No DTEND used in this ICS file....Toonz wrote:Can you try file:///.... (three slashes....). Haven't tried myself...
2018-12-17 (*) Birthday of <Person A>
2018-12-22 (*) Birthday of <Person A>
2018-12-24 Kerstavond
2018-12-25 Eerste kerstdag
2018-12-26 Tweede kerstdag
2018-12-30 (*) Birthday of <Person A>
2018-12-31 Oudejaarsavond
2019-01-01 (*) Birthday of <Person A>
2019-01-01 Nieuwjaarsdag
2019-01-09 (*) Birthday of <Person A>
2019-01-16 (*) Birthday of <Person A>
2019-01-17 (*) Birthday of <Person A>
2019-01-22 (*) Birthday of <Person A>
.........etc.
Wait for 1.0.11 to fix the missing end dates
Thank you Toonz, I just installed 1.0.10 and it brings a smile to my face.Toonz wrote:Hi all,marcog wrote:Is it an option when Toon is in a dim state to show the date of the upcoming event in a format like "Today at 08:00" or "Wed 12 December 2018 08:00" instead of "12 December 2018 08:00". I'm not that good in remembering the current date so this would be a nice add-on.
version 1.0.10 is available in ToonStore.
Changelog:
- date of the first appointment on the tile in dim state now shows as 'vandaag', 'morgen' and 'overmorgen' for the coming three days.
- Later dates are including the short day name, now formatted as "Ma 18 december" on the tile in dim state.
- Appointment title is now the top row, date and time the bottom two rows in dim state
I guess this will be the last update for now (unless bugs are found), focus will be on getting ToonStore and apps running on firmware 5.0.x
Kind regards,
hi all,
version 1.1.0 is released on ToonStore. This is the first installation package which is compatible with firmware 4 and firmware 5 (when the newly modded resource files are released)
Changelog:
- if the end-date is missing, I assume that the enddate is the same as the startdate (might leave it blank in the future)
This version will show entries correctly without end-dates like the space launch calendar and others.
Kind regardz,
Changelog:
Kind regardz,
@Toonz
My Toon1 does not like this version of the Calendar .
When i load my private google url (Its the only one i put in settings file), after about 5min, Toon crash and reboot itself.
That's not good, is it on a Toon 1 or Toon 2? Which firmware?mAiden wrote:@Toonz
On Toon1 on firmware 5.0.1. Have got the resourcefile from Thehog.Toonz wrote:That's not good, is it on a Toon 1 or Toon 2? Which firmware?mAiden wrote:@Toonz
ok, I have tested it on a Toon 1 on 4.22, it even loads the huge space calender properly and on a Toon 2 on 4.22 and a Toon 2 on 5.0.1 without issues.mAiden wrote:On Toon1 on firmware 5.0.1. Have got the resourcefile from Thehog.Toonz wrote:That's not good, is it on a Toon 1 or Toon 2? Which firmware?mAiden wrote:@Toonz
I don't have a Toon 1 on 5.0.1 at the moment.
could it be that Toon runs out of memory? Does deleting other custom apps help (or even better, disable a lot of the internal apps)?
Give me 3 mins, lets boot my laptop.
Will look in Toon. Give you some screens, even better watch with me with teamviewer?
Think this one it the problem Toonz, remove it with opkg remove, but when i installed it agian, got this:
Installing calendar (1.1.0-r0) to root...
Running preinstall for calendar-1.1.0
Older installation detected.
Backing up previous settings ...
Pre-inst script completed
Need to remove older installation.
Thinking about it, it is probably best to completely uninstall all custom apps before or right after upgrading to fw5 and then install everything again.mAiden wrote:Think this one it the problem Toonz, remove it with opkg remove, but when i installed it agian, got this:
Have removed all custom apps, and reinstalled the calendar. Now he picks up the standard calender.Toonz wrote:Thinking about it, it is probably best to completely uninstall all custom apps before or right after upgrading to fw5 and then install everything again.mAiden wrote:Think this one it the problem Toonz, remove it with opkg remove, but when i installed it agian, got this:
I'm curious what it does with my own calendar in it now.
//EDIT:
Crash agian and Toon reboot himself with my own .ICS file in it.
App works ok with the stabdard calender in it. But when a add my own in it, it's goes wrong.
can you email me your ics file for debugging?mAiden wrote:App works ok with the stabdard calender in it. But when a add my own in it, it's goes wrong.
It handles the launch calendar okay but the birthday calendar just like before.Toonz wrote:Wait for 1.0.11 to fix the missing end dates
