Toon app: mySolar (FP4ALL)
oepi-loepi
Re: Toon app: mySolar (FP4ALL)
Post by oepi-loepi »
Ridder wrote:Just installed my rooted Toon and it has mySolar installed.
I put the IP address of my inverter in (Growatt 3600 MTL) but there are no data on Toon...
When I connect to the inverter with its IP address in a browser, I need to put in my login name and password.....where can I do that on the Toon?
I also have a kWh meter and `i connected it to Toon, but I am not shure if I connected it the right way....on 1 terminal I put the white wire (that should be the left channel/tip of the jack plug) and the others on the other terminal: red and common ground (the metal shielding of the 2 wires).
Should it be visible on the meter adapter if it is receicing pulses?
Now both leds blink every ~10m seconds (flame and lightning)
Gas and electricity consumption via P1 work fine.....
You can use the solarPanel app in toon instead. That one is able to read the Growatt inverter.
Aussie
Post by Aussie »
both don't work mySolar (FP4ALL) 1:off
and SolarPanel shows Zon Nu: nanW.
Vandaag: 0,0 KWh
Lev: 0W
Verbruiuk: 377 W deze klopt
Zon op Toon werkt wel bij mij.
Zelf een KWH meter met S0 gekocht en aangesloten
