Page 2 of 2
Re: Developing apps for Toon
Posted: Sun Dec 29, 2019 5:42 pm
by TerrorSource
@hvxl
I'm testing with the local image file (2.3 in the document) but seems i cant get it working..
Logs:
file://qmf/qml/apps/xxx/xxxTile.qml:53:2: QML Image: Error transferring
http://localhost/images/xxx/xxx_large.jpg - server replied: Not Found
qml file:
source: "
http://localhost/images/xxx/xxx_large.jpg"
image file:
/HCBv2/qml/images/xxx/xxx_large.jpg
Posted: Mon Dec 30, 2019 12:09 am
by hvxl
I just tested it again to make sure it works. This is the code I used (in directory /HCBv2/qml/apps/xxx):
XxxApp.qml:
import QtQuick 2.1
import qb.base 1.0
App {
property url tileUrl: "XxxTile.qml"
function init() {
const args = {
thumbCategory: "general",
thumbLabel: "Xxx",
thumbIcon: "qrc:/images/unknown.svg",
thumbIconVAlignment: "center",
thumbWeight: 30
registry.registerWidget("tile", tileUrl, this, null, args);
XxxTile.qml:
import QtQuick 2.1
import qb.components 1.0
Tile {
Image {
anchors.centerIn: parent
source: "http://localhost/images/xxx/xxx_large.jpg"
- Xxx tile screen shot
- toonfb0001.png (21.39 KiB) Viewed 28206 times
What happens if you try to access the file from the command line?:
cd /tmp
wget
I'm doing this on a toon 1. I expect it works on toon 2 as well, but I don't have one to test that assumption.
Posted: Wed Jan 15, 2020 7:39 pm
by ralph123
I'm a newbie in building apps. I'm looking into showing the values of my SolarEdge inverter.
Is it a lot of work to build an app that shows only 1 value. SolarEdge has an api. Andy I found a pyton script.
https://pypi.org/project/solaredge/
For history etc. I use the SolarEdge app. It's nice to see the current Kw/h of the solarpanels on my Toon.
Posted: Thu Jan 16, 2020 2:41 pm
by TheHogNL
ralph123 wrote:I'm a newbie in building apps. I'm looking into showing the values of my SolarEdge inverter.
Why not invest in a 25 euro kWh meter and then use the native solar app on the Toon? The values from the solaredge api are only updated once per 5 minutes.
Posted: Wed Mar 11, 2020 10:44 pm
by glsf91
Sorry for deleting my previous posts, I solved them finally.
I want to test the thumbnail icon for my application.
If I try: property url thumbnailIcon: "
http://localhost/nl-icon.png"
I get the error: qrc:/apps/homescreen/TileThumbnail.qml:73:3: QML Image: Failed to get image from provider: image://scaled//localhost/nl-icon.png
I know I can use above url for an image elsewhere in the app, but I want to test it for the thumbnail icon.
Is there a way to test my own thumbnail icon before it is in the TSC resource file?
Edit:
Answer: above is not possible. Has to use resourcefile for thumbnail
