Toon app: ToonBot
Re: Toon app: ToonBot
Postby glsf91 » Sun Oct 18, 2020 8:28 pm
Henrihendriksen wrote:Firmware is 5.33.9
Looks like webserver is not running.
Can you post complete output of: netstat -an|grep LISTEN
Did you already try a restart of Toon (so reboot complete Toon)?
glsf91
Postby Henrihendriksen » Sun Oct 18, 2020 8:37 pm
netstat: /proc/net/tcp6: No such file or directory
netstat: /proc/net/udp6: No such file or directory
netstat: /proc/net/raw6: No such file or directory
tcp 0 0 0.0.0.0:22 0.0.0.0:*
LISTEN
tcp 0 0 127.0.0.1:1337 0.0.0.0:*
LISTEN
I restarted the Toon several time. Also /etc/init.d/iptables restart
Henrihendriksen
Postby glsf91 » Sun Oct 18, 2020 10:17 pm
LISTEN
LISTEN
Maybe best to start a topic in the Toon firmware forum about missing webserver.
glsf91
Postby Henrihendriksen » Mon Oct 19, 2020 7:28 am
Thanks, I will. For my information: where is the debug information stored when DEBUG is switched to Yes (console.log information)?
Henrihendriksen
Postby glsf91 » Mon Oct 19, 2020 3:28 pm
Debug is indeed in the console log. You have to start the Toon GUI is a special way so console log (and much more) is written to a file. Then you can search in this file for the debug info. Basically it is intended for when you modify the app. For normal use it is better not to enable debug.
glsf91
Postby Henrihendriksen » Tue Oct 20, 2020 12:01 pm
Webserver now running and BOT is working. Many thanks!
Henrihendriksen
Postby Daniel » Sat Oct 31, 2020 3:13 pm
Thanks for great work,
Is it possible to receive a message when the smoke detector goes off? Toon display change color.
Yesterday i was forgotten the deep fryer which fortunately caused the smoke detector to go off. :roll:
Daniel
Postby glsf91 » Sat Oct 31, 2020 4:22 pm
Daniel wrote:Thanks for great work,
I have no idea if it is possible. I also have no smoke detector so I can also not test.
For now I have to skip this question.
glsf91
Postby glsf91 » Sun Jan 31, 2021 8:35 pm
I added the smokedetector alarm in V1.4.0.
glsf91
Previous
Return to Toon Apps
Users browsing this forum: Google [Bot] and 1 guest
