glsf91 wrote:Henrihendriksen wrote:I tried the line from the browser but the response is that the site is not available.
This is the cause it is not working. Looks like the Toon is not listening on port 80.
If you login on the Toon bij SSH you should see with this command: netstat -an|grep LISTEN
tcp 0 0 0.0.0.0:10080 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
(and more)
The second line should be there. Do you have that line?
And which firmware version do you use?
Also post content of cat /etc/default/iptables.conf
There is no line with 80 or 10080. So you are right that is does not respond to http
My iptables:
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:HCB-INPUT - [0:0]
-A INPUT -j HCB-INPUT
-A FORWARD -j HCB-INPUT
-A HCB-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# These are all closed for Quby/Toon:
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
#-A HCB-INPUT -p udp -m udp --sport 67:68 --dport 67:68 -j ACCEPT
#-A HCB-INPUT -p udp -m udp --dport 137:138 -j ACCEPT
-A HCB-INPUT -i lo -j ACCEPT
-A HCB-INPUT -i tap+ -j ACCEPT
-A HCB-INPUT -i tun+ -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --tcp-flags SYN,RST,ACK SYN -j DROP
-A HCB-INPUT -p udp -m udp -j DROP
COMMIT
