Enphase AND SMA info
Postby Joskep » Sat May 16, 2020 2:59 pm
Hello, an question:
Because i see an Solar app i was wondering...
I have got two different Solar panel systems; ENPHASE and Sma. Both are accesible via local IP-addreses.
That i was wondering:
https://enphase.com/nl-nl/support/wat-a ... e-gebruikt
As example i see that the ENPHASE system can work via API.
isn.t it possible to adjust the code of the excisting APP and change the code so i can see the information of this systems?
I think i don.t need any sensor, because both systems work already via local acces and aps.
Or is this to simple?
Joskep
Re: Enphase AND SMA info
Postby Joskep » Sat May 16, 2020 7:51 pm
Edit:
https://www.domoticaforum.eu/viewtopic. ... 9&start=30
Looks like there where a few before, not as easy as hoped i guess ;-(
Joskep
Postby Joskep » Thu Jun 11, 2020 5:28 am
For who it ever wants, without 'Zon op Toon'...
I installed an Raspberry Pi with Domoticz. Via an .py script the solar panels are communicating withe the dasboard, so an free solution to add them to the Toon is possible if the Toon app Domoticz integrates it.
Already asked in another topic, maybe in the future.
But know that it works, via this script for the SMA:
https://github.com/merlot-dev/Domoticz-SMA-SunnyBoy
The Enphase is standard already integrated within the sensors.
Joskep
Re: Enphase AND SMA info UPDATED Question
Postby Joskep » Tue Jan 19, 2021 3:00 pm
Hello guys, an Domoticz question:
Because of the fact that one of my solar panel systems (SMA) won't work with Oepie-Loepi's nice Solar app...
Within my Domoticz dashboard i can see two ' virtual sensors' . Those sensors give me all the information about my solarpanel sets.
(This works fine within my mobile phone, tablet etc but as i earlier said not on my Toon, only switches are shown).
What i thought would work:
1. Make an virtual sensor "PVOutput' (input)", give the credentials from the PVoutput-profile (username and password)
2. Install Oepi-loepi's Solarapp and choose for ' inverter type' "PVOutput" .
It sounds very easy, what i does:
the SMA inverter gives information to > domoticz > PVOutput gives information to > Toon solar-app
Will this work or do i have to make an LUA script for this. I think an script need to collect data from both ' sensors' (SMA and ENPHASE inverter) and had to share it with the PVOutput website?!
Hopefully somebody could advise.
1 thing that works great: Both inverters give nice stats which i can see within my domoticz dashboard
Joskep
Return to Toon Apps
Users browsing this forum: oepi-loepi and 1 guest
