Toon App: Zappi (EV charger)
I recently added a Zappi EV charger to my home installation. The zappi, combined with the hub, provides a connectivity to the internet from which you can get some information from the charging state of your EV.
I started developing a Toon app for this and it is still in beta but already functional, see for an example: https://www.youtube.com/watch?v=p4YZskoqkaw
I'm looking for other rooted Toon and Zappi users to further test the app. Please let me know if you have a Zappi with hub (and a rooted toon ofcourse).
Re: Toon App: Zappi (EV charger)
ask @tweakers ? if you had no response yet..
Thanks. Just asked in the EV homecharger topic.vso wrote:ask @tweakers ? if you had no response yet..
Hi TheHog, I'm here (from the tweakers forum)
I would like to test the Zappi app on the Toon.
Hi, welcome!
Did I understand correctly you don' t have a rooted toon yet?
I now have a rooted toon
Ok great.Isheara wrote:I now have a rooted toon
I just released zappi 1.0.0 in the toonstore. You will also need to press 'check update' in the TSC menu to get the latest resource files (containing the zappi graphics) and need to have firmare 5.30.4 (I have only put the zappi graphics in the 5.30.4 resource file).
Let me know how it works for you. Do you have a 3-phase or 1-phase zappi?
I ordered a 3 phase zappi but the 3x25A will only be installed on 11th of August. De zappi will be installed next week on Monday the 20th.
The zappi app loaded I will keep you posted on the functionality
Ok on 3 phase the app will work perfectly because I have 3 phase also I was wondering on the 1 phase config so lets wait on more testersIsheara wrote:I ordered a 3 phase zappi but the 3x25A will only be installed on 11th of August. De zappi will be installed next week on Monday the 20th.
Zappi on toon works very well! Thank you @thehogNL
Hi! Happy to use the Zappi app on my 3 phase for a few months now. Great to have this feature on Toon. However the last few days the info on Toon isn't correct. It says disconnected, while connected and charging.
Is the app working on your phone? Did you upgrade the zappi app on toonstore?Alxwin wrote:Hi! Happy to use the Zappi app on my 3 phase for a few months now. Great to have this feature on Toon. However the last few days the info on Toon isn't correct. It says disconnected, while connected and charging.
Never saw your response. Have the same issue again, after it magically solved itself last year. The app is working fine, but Toon keeps saying disconnected.
Already restarted Toon and Zappi. But without result.
There is an zappi toon app update.
Also make sure you are using the Zappi API key as password from now on and not the app password
