Toon App: solarPanel ---> solar data without hardware
Postby oepi-loepi » Sat Jan 09, 2021 8:42 pm
In Toonstore Now
From now on it is possible to connect your solar inverter to Toon without the use of cables or hardware.
Even two inverters is now possible (from version 1.3.1.
If you allready have a hardwired solution for this (extra meter and meteradapter): keep the hardwired solution. If you like to change solution to this solution: disable the meteradapter solution first otherwise you get double amounts.
- Install the app
- install a tile
- click on the tile and goto the configuration screen
- select one of the inverters and fill in your credentials
- click "opslaan". Your Toon will be modified for the use of solar features
After installation, more solar features will become visible in the tile setup.
For now the following inverters are available in the setup:
- APS (Altenergy) via portal
- domoticz. Connect via domoticz. (For 1 inverter, give 1 IDX. For 2 inverters give 2 IDX like 14+19)
- enPhase 1 (local version)
- enPhase 2 (API key and user_id needed, fill your user_id in the gebruikersnaam field)(domoticaforum.eu/viewtopic.php?f=99& ... =60#p96841)
- FP4ALL dataloggers
- Fronius
- Growatt
- Goodwe
- kostal piko
- omnik via portal
- omnik local
- pvoutput portal
- sma (for SB1.5, SB 3.0 etc)
- sma (for tl series) (domoticaforum.eu/viewtopic.php?f=99& ... =60#p96807)
- SolarEdge (domoticaforum.eu/viewtopic.php?f=99& ... =30#p96629)
- Solis (Ginglong)
- zeversolar
Further testing needed:
- all inverters above have been successfully tested
Not working:
- please let me know
If you like to have your inverter available as well, please send me a message and i will look into programming an interface.
The first day will have an enormous amount in the graphs. This because the day amount is calculated from the inverter's total amount.
oepi-loepi
Re: Toon App: solarPanel ---> solar data without hardware
Postby Ron_nl » Sun Jan 10, 2021 11:06 am
Very nice work! 8)
I do have a SMA inverter, but it is using bluetooth for reading its data.
Keep up the good work!
Ron.
Ron_nl
Postby rleunk » Sun Jan 10, 2021 1:04 pm
Have sent you login details for my SMA inverter, good luck with the further development of the app.
rleunk
rleunk
Postby Floris25 » Tue Jan 12, 2021 2:44 pm
I Have an SMA device also: connected with UTP. And a Toon 1 (version 5.33.9)
I could do some testing for you if you needed?
Just let me know.
Kind regards
Floris
Floris25
Postby oepi-loepi » Tue Jan 12, 2021 11:23 pm
Floris25 wrote:I Have an SMA device also: connected with UTP. And a Toon 1 (version 5.33.9)
Just let me know.
Kind regards
Floris
Zou je svp kunnen testen of jouw sma lokale toegan heeft?
in browser de volgende regel waarbij
smipadress is het adres van je omvormer
jouwwachtwoord = gebruikerswachtwoord van de omvormer
http://smaipadress/dyn/login.json?pass= ... &right=usr
alvast dank!
oepi-loepi
Postby Floris25 » Wed Jan 13, 2021 11:14 am
alvast dank!
doet helaas niets: Mijn SMA hangt wel in het netwerk (ik kan hem pingen). maar met de regel die je me doorgeeft krijg ik alleen een timeout
Floris25
Postby oepi-loepi » Wed Jan 13, 2021 5:11 pm
wat is het type van jouw omvormer?
oepi-loepi
Postby jozg » Wed Jan 13, 2021 7:00 pm
Hello Oepie Loepie,
I tried the solarpanel app, and installed via the test repository.
I'm using a Growatt inverter and i setup my credentials ok, but the figures stays zero.
When i login to http://server.growatt.com i see that today i have 1.7KWh, but the app says 0.
I allready give my toon a factory data reset, so all my tables are clear.
Is there possible something else wrong?
Thanks for the good work, it looks very promissing!.
Regards,.
jozg
Postby oepi-loepi » Wed Jan 13, 2021 10:45 pm
I am working on some updates for the daily totals. Please try tomorrow if you receive cuurent power when the sun shines if you still do not receive any data please check your credentials again. It must be an emailadres and a password.
oepi-loepi
Postby jozg » Wed Jan 13, 2021 10:59 pm
My credentials are a username and password. So i'm not using a emailaddress as login name.
I can login to http://server.growatt.com with a single username and password.
Could that be a problem?
jozg
Postby Floris25 » Thu Jan 14, 2021 9:54 am
oepi-loepi wrote:wat is het type van jouw omvormer?
SMA Sunnyboy
SB 3600TL-21
Floris25
Postby oepi-loepi » Thu Jan 14, 2021 11:42 am
SMA Sunnyboy
SB 3600TL-21
ik ben eerder bezig geweest (en ben nog bezig) met een SB300TL-21 ik denk dat dat hetzelfde is. Die is idd niet op deze manier benaderbaar.
oepi-loepi
Postby oepi-loepi » Thu Jan 14, 2021 12:14 pm
jozg wrote:Hello,
The plugin has been updated to version 1.0.8
oepi-loepi
Postby Floris25 » Thu Jan 14, 2021 2:59 pm
oepi-loepi wrote:
SMA Sunnyboy
SB 3600TL-21
Op deze site https://robothuis.nl/2020/01/13/zonnepa ... -domoticz/ staat een verwijzing naar github om SMA data uit te lezen in domoticz.
Ze halen daar de data van het internet af (dus niet rechtstreeks vanaf de omvormer die in het LAN zit) in geval van SMA zou je dan tegen 'http://www.sunnyportal.com" aan moeten gaan praten.
Op sunnyportal heb ik een account waar ik mijn eigen productie kan inzien.
de data zou dan gaan van: mijn omvormer --> http://www.sunnyportalcom --> SolarPanel op mijn Toon
is dat ook een optie?
Groeten Floris
Floris25
Postby Hansb » Thu Jan 14, 2021 3:32 pm
Hallo
Dit ziet erg erg goed uit. Toppie.
Zal veel werk in zitten.
Ik ben hier nieuw en net begonnen om de Toon te ontdekken .
Ik ziet dat de Growatt omvormer ook zichtbaar te maken is, maar dat je daar een app voor nodig hebt die u ontwikkeld heeft. Kan ik die app ergens downloaden en hoe zet ik hem dan in de Toon?
Vriendelijke groeten
Hans
Hansb
Next
Return to Toon Apps
