Toon App: solarPanel ---> solar data without hardware
Re: Toon App: solarPanel ---> solar data without hardware LIVE
Postby oepi-loepi » Mon Jan 18, 2021 12:44 pm
Joskep wrote:@OepieLoepie:
The Enphase panels work as i mentioned.
Now i'm testing with the SMA, like you asked another on this topic i did this:
http://smaipadress/dyn/login.json?pass= ... &right=usr
The result is:
" {"result":{ "
Maybe an start?
Its an SMA Sunnyboy 1.5 and its called " SB1.5-1VL-40 544 " as a device name within the settings
Before i test to change the URL / IP in the app (like : "http://smaipadress/dyn/login.json?pass= ... &right=usr" in stead of only ' 192.168.1.64' )...
Is it possible to add TWO systems at one time? Or do i have to overwrite the Enphase?
If its not possible then i wouldn't work ever so i don;t spend to much time and wait untill somebody makes sensors visible within the Toon gui :)
That is great News! You have a sma with an http entrance. Are you willing to help me testing further (please send me a pm)?
oepi-loepi
Postby oepi-loepi » Mon Jan 18, 2021 12:52 pm
edwinbak wrote:Hello,
Thanks for developing this app, it looks great!
I am using SolarEdge API and have entered this data in the settings panel.
I know there is a limit to the SolarEdge API and that their own app fetches data every 15 minutes because of this, how is this set up in your app?
At the moment no data about my solar panels is coming in. Is there a log file somewhere so I can check what is going wrong?
I have already checked the Site ID and API key and they are okay.
Like to hear from you!
Thanks,
Edwin
For the Solaredge, you have to enter the API key and the SiteID just like you have done and it must work. Data is catched every 5 minutes and does not any problems according to theur API description.
Dit all reboot after the Setup? Can you force an update of teh plugin?
you can check the output by entering this url in a browser:
https://monitoringapi.solaredge.com/sit ... bbbbbbbbbb
where
aaaaaaaaaaaaaaaaaaa = site id
bbbbbbbbbbbbbbbbbb = apikey
oepi-loepi
Postby Joskep » Mon Jan 18, 2021 1:09 pm
The result is:
" {"result":{ "
Maybe an start?
Offcourse! I will send an PM
Joskep
Postby edwinbak » Mon Jan 18, 2021 2:14 pm
Thanks,
Edwin
where
Here is the output:
{"overview":{"lastUpdateTime":"2021-01-18 13:35:11","lifeTimeData":{"energy":381034.0,"revenue":27.380013},"lastYearData":{"energy":55517.0},"lastMonthData":{"energy":55517.0},"lastDayData":{"energy":3038.0},"currentPower":{"power":1022.3147},"measuredBy":"INVERTER"}}
There's a limit of 300 API calls per day i believe.
Is it possible to change the frequency from every 5 minutes to 15 minutes interval in the source code?
I have another system that make some API calls every 15 minutes so that could be a problem at the end of the day.
60 / 5 = 12x in 1 hour x 24 hours = 288 calls per day.
60 / 15 = 4x in 1 hour x 24 hours = 96 calls per day
288 + 96 = 384 calls per day so the api will block the last 84 calls i think.
Is it possible to make the frequency a variable setting in the app?
edwinbak
Postby Demif » Mon Jan 18, 2021 2:35 pm
is this working on the toon 1? firmware 5.0.6
I installed the app via app store,
there is no tile active,
any idea's
Demif
Postby oepi-loepi » Mon Jan 18, 2021 3:41 pm
The toon is fetchin 12 times per hour between 5 - 2300 so 23-5 = 18 hrsx12 = 216 times per day. So it should normally not be a problem. Longer times will be a problem for the graphs to display.
The output of the URL looks very OK. If you like you can share your Key by PM so i can check my plugin?
oepi-loepi
Postby oepi-loepi » Mon Jan 18, 2021 3:44 pm
Demif wrote:is this working on the toon 1? firmware 5.0.6
any idea's
You should really update your Toon because it will be faster and will have a lot of new features like the Animation app, Voetbal app and this feature: solarPanel.
To update your rooted toon. Go to the settings menu, TSC menu and check for updates on the top.
oepi-loepi
Postby edwin999 » Mon Jan 18, 2021 5:13 pm
Feature request: can you add sunrise- and sunset times in the Solar (full display) graph? I.e.
- sunrise and sunset times (as text)
- sunrise and sunset as vertical bar in the graph
edwin999
Postby Demif » Mon Jan 18, 2021 5:37 pm
any idea's
it is not possible to update , i have one of the toons that can't update ( only by restore ) and i just restored :cry:
Demif
Postby TerrorSource » Mon Jan 18, 2021 6:01 pm
any idea's
did you lose the VPN keys or did you had your Toon rooted by Quby?
If yes, let me know, got some spare VPN keys.
TerrorSource
Postby edwinbak » Mon Jan 18, 2021 6:07 pm
Ok, this is strange.
This morning it wasn’t showing anything but 0.
When I came home there was data on my toon!
Thanks!
Another question, why is there a big difference between your ‘verbruik’ and the measurement from Toon?
And is it possible to show 2 decimals behind the . ? Now it is showing ‘Vandaag: 4.0 kwh’ maybe you should show ‘4.00 kwh’
edwinbak
Postby oepi-loepi » Mon Jan 18, 2021 6:20 pm
Thanks!
Verbruik and "stroom Nu" from Toon should be more or less the same (in a 20s interval)
oepi-loepi
Postby Demif » Mon Jan 18, 2021 6:51 pm
If yes, let me know, got some spare VPN keys.[/quote]
Yes VPN key
Demif
Postby TerrorSource » Mon Jan 18, 2021 9:05 pm
Demif wrote:did you lose the VPN keys or did you had your Toon rooted by Quby?
Yes VPN key[/quote]
Send me an email or PM if you need VPN-keys.
TerrorSource
Postby clvgtnl » Wed Jan 20, 2021 1:09 pm
Beste oepi-loepi,
Mooie app, ik ben hier heel blij mee.
Alleen heb ik een vraag, is het mogelijk om 2 omvormers in te stellen? Want op dit moment is dat niet mogelijk of wel?
Ik heb de Growatt en de Goodwe. Thanks :)
clvgtnl
PreviousNext
Return to Toon Apps
