I have it on my Toon1:
eneco-001-00xxxx:~# which crontab
/usr/bin/crontab
toon:~# opkg files cron
Package cron (3.0pl1-r8) is installed on root and has the following files:
/etc/init.d/cron
/var/cron/tabs/
/var/cron/
/usr/bin/crontab
/usr/sbin/cron
eneco-001-14****:~# opkg files cron
Collected errors:
* opkg_files_cmd: Package cron not installed.
4nuts wrote: ↑Sun Apr 10, 2022 11:08 am The python code does the following:
-1- Setup an SSH connection to the Toon
-2- Daily @ 4 am it sents out the ssh command /sbin/shutdown -r now , the Toon will reboot and freeup the memory.
-3- every minute send the following command to the Toon : uptime , free and iostat -c 1 1 and store the results in Homeassistant via MQTT.
Great ! now crontab is running on my Toon1.Toonz wrote: ↑Sat Apr 16, 2022 8:51 pm cron ipk can be found here: http://files.domoticaforum.eu/index.php ... on/ipk/qb2
install via "opkg install http://files.domoticaforum.eu/uploads/T ... r8_qb2.ipk"
