Controlling Toon via Domoticz
- madpatrick
- Member
Re: Controlling Toon via Domoticz
Not sure if i can follow your question and scripts.
Are those all separate scripts ? If you, disable them and enable them one by one to see which script gives the error.
Dev_37 is mentioning : "CurrentElectricityFlow": "0.00" in your output of http://TOON IP/hdrv_zwave?action=getDevices.json
I believe dev_37 is for Solar panels ?
I'm currently using one of your scripts, found on domoticz.com (I think) and fixed the dev errors. I do have solar panels, so will try using dev_37 tomorrow. Still get some funny readings on my boiler pressure (1.6 bar) and gas usage for one day, but I think I have to try using the other dev values while looking at my Toonmadpatrick wrote:Not sure if i can follow your question and scripts.
This is your script I'm using now:
-- Toon script for rooted TOON systems
-- credits: user madpatrick from domticz.com forum
-- version 1.01
-- date 15042021
-- script runs every 1 minute
local scriptVersion = 'Versie 1.01 '
local scriptVar = '-=# TOON Script #=-'
return {
on = { timer = {'every minute'},
logging = { level = domoticz.LOG_ERROR,
marker = scriptVar },
execute = function(domoticz)
local ToonThermostat = 'Toon Thermostaat' -- Sensor showing setpoint (thermostaat waarde van Toon)
local ToonTemperature = 'Temperatuur Kamer' -- Sensor showing room temperature
local ToonAutoProgram = 'Toon Auto Program' -- Sensor showing auto program status
local ToonBoilerModulation = 'ModulationLevel' -- * Sensor showing Boiler Modulation
local ToonScenes = 'Toon Scenes' -- * Sensor showing program
local ToonBoilerSetpoint = 'Ketel Setpoint' -- * Sensor showing boiler temperature set point
local ToonBoilerTempIn = 'Ketel Temp IN' -- * Sensor showing water temp return
local ToonBoilerTempOut = 'Ketel Temp UIT' -- * Sensor showing water temp out
local ToonBoilerPressure = 'Keteldruk' -- Sensor showing boilerpressure
local ToonBurnerName = 'Ketelstand' -- Sensor showing boiler modus
local P1SmartMeterPower = 'P1 Elektra' -- Sensor Energy consumption
local P1SmartMeterGas1 = 'P1 Gas' -- Sensor Gas consumption
local ToonIP = '192.168.2.xxx -- IP address of your Toon
local DomoticzIP = '192.168.2.xxx:xxxx' -- IP address and portnumber of your Domoticz server
local SetPointAway = 18.5 -- temperature of setpoint Away
local SetPointSleep = 17.0 -- temperature of setpoint Sleep
local SetPointHome = 20.0 -- temperature of setpoint Home
local SetPointComfort = 20.5 -- temperature of setpoint Comfort
local ToonProgramInformation= 'ToonProgramInformation' -- Sensor showing current Program
-- Handle json
-- Choose the correct platform which Domoticz runs on
-- Remove -- before the line which applies for your situation, set -- for all other platforms
-- local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Raspberry
-- local json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
-- local json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")() -- For Linux (ClearOS)
local json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
end
local handle2 = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
local BoilerInfo = handle2:read('*all')
handle2:close()
-- JSON data from Toon contains a extra "," which should not be there.
BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
jsonBoilerInfo = json:decode(BoilerInfo)
-- http://IP_TOON/hdrv_zwave?action=getDevices.json
local handle4 = assert(io.popen(string.format('curl http://%s/hdrv_zwave?action=getDevices.json', ToonIP)))
local GasPowerInfo = handle4:read('*all')
handle4:close()
-- JSON data from Toon contains a extra "." which should not be there.
GasPowerInfo = string.gsub(GasPowerInfo, "dev_4.", "dev_4") -- match your device numbers according to your own config
GasPowerInfo = string.gsub(GasPowerInfo, "dev_4:", "dev_4\":") -- match your device numbers according to your own config
local jsonGasPower = json:decode(GasPowerInfo)
-- Update the powerconsumption
local CurrentElectricityFlowHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityFlow) --stroomverbruik momenteel hoogtarief
local CurrentElectricityFlowLaag = tonumber(jsonGasPower.dev_45.CurrentElectricityFlow) --stroomverbruik momenteel laagtarief
local CurrentElectricityQuantityHoog = tonumber(jsonGasPower.dev_44.CurrentElectricityQuantity) --stroomverbruik totaal hoogtarief
local CurrentElectricityQuantityLaag = tonumber(jsonGasPower.dev_45.CurrentElectricityQuantity) --stroomverbruik totaal laagtarief
local CurrentElectricityDeliveredHoog = tonumber(jsonGasPower.dev_46.CurrentElectricityQuantity) --stroomgeleverd momenteel hoogtarief
local CurrentElectricityDeliveredLaag = tonumber(jsonGasPower.dev_47.CurrentElectricityQuantity) --stroomgeleverd momenteel laagtarief
local CurrentElectricityDeliveredFlowHoog = tonumber(jsonGasPower.dev_46.CurrentElectricityFlow) --stroomgeleverd momenteel laagtarief
local CurrentElectricityDeliveredFlowLaag = tonumber(jsonGasPower.dev_47.CurrentElectricityFlow) --stroomgeleverd momenteel hoogtarief
local PowerConsumption = CurrentElectricityFlowHoog + CurrentElectricityFlowLaag --stroomverbruik totaal aktueel
local PowerProduction = CurrentElectricityDeliveredFlowHoog + CurrentElectricityDeliveredFlowLaag --stroomverbruik totaal geleverd
--USAGE1= energy usage meter tariff 1
--USAGE2= energy usage meter tariff 2
--RETURN1= energy return meter tariff 1
--RETURN2= energy return meter tariff 2
--CONS= actual usage power (Watt)
--PROD= actual return power (Watt)
--updateP1(usage1, usage2, return1, return2, cons, prod): Function. Updates the device. Supports command options.
domoticz.devices(P1SmartMeterPower).updateP1(CurrentElectricityQuantityLaag, CurrentElectricityQuantityHoog, CurrentElectricityDeliveredLaag, CurrentElectricityDeliveredHoog, PowerConsumption, PowerProduction).silent()
domoticz.log('P1 : Meter Verbruik laagtarief : ' .. CurrentElectricityQuantityLaag/1000 .. ' kWh ', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Verbruik hoogtarief : ' .. CurrentElectricityQuantityHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Levering laagtarief : ' .. CurrentElectricityDeliveredLaag/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Meter Levering hoogtarief : ' .. CurrentElectricityDeliveredHoog/1000 .. ' kWh', domoticz.LOG_FORCE)
domoticz.log('P1 : Huidig Stroom Verbruik : ' .. PowerConsumption .. ' W', domoticz.LOG_FORCE)
domoticz.log('P1 : Huidig Stroom Opbrengst : ' .. PowerProduction .. ' W', domoticz.LOG_FORCE)
-- Update the gasconsumption
local CurrentGasFlow = tonumber(jsonGasPower.dev_41.CurrentGasFlow)
local CurrentGasQuantity = tonumber(jsonGasPower.dev_41.CurrentGasQuantity)
domoticz.devices(P1SmartMeterGas1).updateGas(CurrentGasQuantity).silent()
-- Update the Boiler Water In to current value
-- local currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
-- currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp)) -- afgeronde getallen is voldoende [PdB]
-- if domoticz.utils.round(domoticz.devices(ToonBoilerTempIn).temperature,0) ~= domoticz.utils.round(currentboilerInTemp,0) then
-- domoticz.log('Update van de CV-water temperatuur IN: ' ..currentboilerInTemp .. ' °C',domoticz.LOG_INFO)
-- domoticz.devices(ToonBoilerTempIn).updateTemperature(currentboilerInTemp).silent()
-- end
-- Update the Boiler water Out to current value
-- local currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
-- currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp)) -- afgeronde getallen is voldoende [PdB]
-- if domoticz.utils.round(domoticz.devices(ToonBoilerTempOut).temperature,0) ~= domoticz.utils.round(currentboilerOutTemp,0) then
-- domoticz.log('Update van de CV-water temperatuur UIT : ' ..currentboilerOutTemp .. ' °C',domoticz.LOG_INFO)
-- domoticz.devices(ToonBoilerTempOut).updateTemperature(currentboilerOutTemp).silent()
-- end
-- Update the Boiler water Pressure to current value
local currentBoilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
currentBoilerPressure = tonumber(string.format("%.1f", currentBoilerPressure)) -- 1 decimaal is voldoende [PdB]
if domoticz.utils.round(domoticz.devices(ToonBoilerPressure).sValue,1) ~= domoticz.utils.round(currentBoilerPressure,1) then
domoticz.log('Update van de waterdruk : ' ..currentBoilerPressure .. ' bar',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerPressure).updatePressure(currentBoilerPressure).silent()
end
-- Update the current temperature setpoint
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
currentTemperature = tonumber(string.format("%.1f", currentTemperature)) -- 1 decimaal is voldoende [PdB]
-- Update the current auto program
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
end
-- Update the current scene by state
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
-- Update the current scene by temperature
local currentActiveTemp = tonumber(jsonThermostatInfo.currentSetpoint) / 100
if currentActiveState == 0 or currentActiveTemp == SetPointComfort then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 or currentActiveTemp == SetPointHome then currentActiveState = 30 -- Home
elseif currentActiveState == 2 or currentActiveTemp == SetPointSleep then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 or currentActiveTemp == SetPointAway then currentActiveState = 10 -- Away
elseif currentActiveState == -1 then currentActiveState = 50 -- Manual
--domoticz.log('Update Toon scene door temperature of Scene wijziging : ' ..currentActiveState,domoticz.LOG_FORCE)
end
-- Update the toon burner selector to current program state
local currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
local CurrentToonBurnerValue = domoticz.devices(ToonBurnerName).level
if currentBurnerInfo == 0 then currentBurnerInfo = 0 -- uit
elseif currentBurnerInfo == 1 then currentBurnerInfo = 10 -- cv aan
elseif currentBurnerInfo == 2 then currentBurnerInfo = 20 -- warmwater aan
-- elseif currentBurnerInfo == 3 then currentBurnerInfo = 30 -- voorverwarmen volgend setpoint
end
-- Update toon burner selector if it has changed
if CurrentToonBurnerValue ~= currentBurnerInfo then
domoticz.log('Update van de ketelstand: ' ..currentBurnerInfo,domoticz.LOG_FORCE)
domoticz.devices(ToonBurnerName).switchSelector(currentBurnerInfo)
end
-- Update the modulation level of the burner
local currentModulationLevel = tonumber(jsonThermostatInfo.currentModulationLevel)
if domoticz.devices(ToonBoilerModulation).percentage + 1 ~= currentModulationLevel + 1 then
domoticz.log('Update van de Modulatie stand: ' ..currentModulationLevel .. ' %',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerModulation).updatePercentage(currentModulationLevel)
end
-- Update the temperature Boiler setpoint to current boiler set point
local currentInternalBoilerSetpoint = jsonThermostatInfo.currentInternalBoilerSetpoint+1
if domoticz.utils.round(domoticz.devices(ToonBoilerSetpoint).temperature, 1) ~= domoticz.utils.round(currentInternalBoilerSetpoint, 1) then
domoticz.log('Update van het ketelwater temperatuur setpunt: ' ..currentInternalBoilerSetpoint .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonBoilerSetpoint).updateTemperature(currentInternalBoilerSetpoint)
end
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostat).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Update van de temperatuur instelling naar: ' ..currentSetpoint .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonThermostat).updateSetPoint(currentSetpoint).silent()
end
-- Update the temperature sensor to current room temperature
if domoticz.utils.round(domoticz.devices(ToonTemperature).temperature, 1) ~= domoticz.utils.round(currentTemperature, 1) then
domoticz.log('Update van de Kamertemparatuur : ' ..currentTemperature .. ' °C',domoticz.LOG_FORCE)
domoticz.devices(ToonTemperature).updateTemperature(currentTemperature)
end
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenes).level ~= currentActiveState then -- Update toon selector if it has changed
domoticz.log('Update van de Toon Scene : '..currentActiveState,domoticz.LOG_FORCE)
domoticz.devices(ToonScenes).switchSelector(currentActiveState).silent()
end
-- Updates the toon auto program switch
if domoticz.devices(ToonAutoProgram).level ~= currentProgramState then -- Update toon auto program selector if it has changed
domoticz.log('Update van het Toon Auto Program : '..currentProgramState,domoticz.LOG_FORCE)
domoticz.devices(ToonAutoProgram).switchSelector(currentProgramState).silent()
end
-- Updates the toon program information text box
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
else
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
end
if domoticz.devices(ToonProgramInformation).text ~= ToonProgramInformationSensorValue then
-- domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformation).updateText(ToonProgramInformationSensorValue)
end
end
- Advanced Member
I think you forgot to post a script. The data collector script you have send is not 64 lines long.. so there is another lua script.
So, now that the seasons are changing once again to colder temperature, I'm glad I found this (again). This time I hope that Toon and Domoticz will keep playing nice with each other.madpatrick wrote:Sure,
Please be aware for the Uservariables etc..... I've changed the names to more logical names
Also i've extended the script with more functionalities. If you do not needed them you can comment them out (or delete)
Once again, my thanks.
Toon® (rooted) | Hue bulbs | TRÅDFRI bulbs | Smart Plugs | some TUYA stuff |
I'm not a programmer, just wish things work MY way
HI, thanks for the script! I'm trying to implement this again after receiving a toonv2. I'm running Linux (Ubuntu) and i've set the json = assert(loadfile to ` /home/user/domoticz/scripts/lua/JSON.lua`. But after the script Domoticz stops working / chrashes.
Any idea what this could be? Something to di with file rights maybe?
I don't know why, but I keep forgetting the dev_ number for my Toon1.
- madpatrick
- Member
Try
See also
https://www.domoticz.com/forum/viewtopi ... 95#p136695
Google does wonders if you need to find something
http://127.0.0.1/hdrv_zwave?action=getDevices.json
Hi. Did anyone manage to get the Toon2 values from the humidity sensor into Domoticz?
I am not much of a programmer, but added / changed something to the script, simular to what was used for the modulation level of the burner:
Off course I also created a sensor:
Dummy 1409B 1 Luchtvochtigheid Binnen Humidity LaCrosse TX3
as well as a user variable of the type String:
UV_ToonHumiditySensorName = Luchtvochtigheid Binnen
Unfortunately this doesn't seem to work, and I don't know what to add to test / log exactly where it fails...
The Domoticz log throws an error at the line :
"attempt to perform an arrithmetic on a nil value"
Besides none of the boiler stuff is working either anymore, so I had to comment-out all of that, as advised in https://ehoco.nl/geroote-toon-bedienen- ... mment-7467
Any help is much appreciated!
... (snip)..
[b] local ToonHumidity = domoticz.variables('UV_ToonHumiditySensorName').value -- Sensor showing current room humidity percentage[/b]
-- Handle json
local json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
... (snip)..
[b]-- Toon2 extra sensor info
local handle3 = assert(io.popen(string.format('curl http://%s/tsc/sensors?action=getDevices.json', ToonIP)))
local SensorInfo = handle3:read('*all') handle3:close()
local jsonSensorInfo = json:decode(SensorInfo)
if jsonSensorInfo == nil then
return
end[/b]
[b]-- Update the Humidity percentage
local currentHumidityLevel = tonumber(jsonSensorInfo.humidity)
if domoticz.devices(ToonHumidity).percentage + 1 ~= currentHumidityLevel + 1 then
domoticz.log('Updating the Humidity percentage sensor to new value: ' ..currentHumidityLevel
domoticz.devices(ToonHumidity).updatePercentage(currentHumidityLevel)
end
[/b]
Never mind, it works now .
There was nothing wrong with the code, but I had used the wrong type of device in Domoticz.
Of course it's not really a humidity sensor type (La Crosse TX3), but a simple percentage sensor...
- madpatrick
- Member
Mocht iemand he tleuk vinden om de vochtsensor uit te lezen, kan je dit toevoegen aan het script
Nu schrijft hij het nog enkel in de log, maar als je een device aanmaakt kan die je dit daar mee uitlezen
Maak een dummy sensor aan met type luchtvochtigheid
xxx is je devicenummer die je hebt aangemaakt
— Vochtsensor
local handle3 = assert(io.popen(string.format(‘curl http://%s//tsc/sensors‘, ToonIP)))
local TSCsensors = handle3:read(‘*all’)
handle3:close()
jsonTSCsensors = json:decode(TSCsensors)
local TSCsensors_hum = tonumber(jsonTSCsensors.humidity)
domoticz.log(‘Luchtvochtigheid: ‘ ..TSCsensors_hum ,domoticz.LOG_FORCE)
domoticz.devices(xxx).update(TSCsensors_hum).silent()
- madpatrick
- Member
For who is interested.
The development of the plugin for Domoticz has been restarted
The script is working of course, but for some users not handy
https://github.com/MadPatrick/domoticz_toon
It is still in development, but working.
Any feedback is more then welcome of course
The best is to give your feedback of GitHub by making an issue https://github.com/MadPatrick/domoticz_toon/issues
Super, running it on a test domoticz on my proxmox server.madpatrick wrote: ↑Tue Jan 03, 2023 4:26 pm For who is interested.
Using it with a toon v2, will let it run for a couple of days and see if there are any problems.
