(Fixed) Toonrooter script hangs at reboot
EricvL
Post by EricvL »
Hi guys,
I bought myself a Pi 3b+ and I installed all necessary software. Now I'm trying to root a deactivated Toon 1 with a R10 bootloader and software version 6. The Toonrooter script seems to be running OK, it does detect the bootloader and seems to load the new one:
[quote]INFO:rooter:Waiting for Toon to restart
INFO:rooter:Toon has U-Boot version 2010.09-R10
INFO:rooter:Loading new bootloader
INFO:rooter:Starting openocd
INFO:rooter:Waiting for 10 seconds
INFO:rooter:Halting CPU
INFO:rooter:Loading new image to RAM
INFO:rooter:Starting up new image
But then nothing happens. I tried again with debug enabled, this is the output:
$ sudo python . --jtag-available --jtag-hardware rpi3 --output-level DEBUG
INFO:__main__:Starting up...
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
DEBUG:__main__:{"uboot_only": false, "has_jtag": true, "check_uboot": true, "boot_only": false, "reboot_after": true, "cleanup_payload": true, "port": "/dev/serial0", "jtag_hardware": "rpi3", "ssh_pubkey_data": "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDrHVWu2QEgdYm4jzUhlyT+Ngy0BHz4bsdqvgAacYlgIhx8Yo9KWgpXI6w2Pm1Tr76Q25i1JVCbhT0DrOJPjNN4Q4J5tDxiqi8ftqQTprpjnX1XAQ1/JZ5CkZksIezOXG6qs4fy+DMJEgMgsOJMdYFcSTjm0YKzvL0rBqrQQ83RKVYvyfRYBBCEaC7uy0b0d0lKPxnVYZ8mksRX3UvdDsfskq8Nnk+MqV4p87v+7M8tYLuI7SXQpL8CQ3EqiVJxCm8mZQ4SkYKrMrG75QlPa7iXBAnrvzFrqA/ik5IWC+bh6F1Khg9O43d+U/ll4a8sFI/LJh7BQ5LO5jerC57V+hTZ"}
DEBUG:rooter:Open On-Chip Debugger
DEBUG:rooter:soft_reset_halt
[imx27.cpu] requesting target halt and executing a soft reset
Jazelle state handling is BROKEN!
target halted in Jazelle state due to debug-request, current mode: Supervisor
cpsr: 0xffffffd3 pc: 0x00000000
MMU: disabled, D-Cache: disabled, I-Cache: disabled
DEBUG:rooter:reset halt
JTAG scan chain interrogation failed: all ones
Check JTAG interface, timings, target power, etc.
Trying to use configured scan chain anyway...
imx27.etb: IR capture error; saw 0x0f not 0x01
Bypassing JTAG setup events due to errors
WARNING: unknown debug reason: 0xf
ThumbEE -- incomplete support
target halted in ThumbEE state due to debug-request, current mode: System
cpsr: 0xffffffff pc: 0xfffffff9
MMU: enabled, D-Cache: enabled, I-Cache: enabled
srst pulls trst - can not reset into halted mode. Issuing halt after reset.
NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'.
DEBUG:rooter:load_image assets/u-boot.bin 0xa1f00000
timed out while waiting for target debug-running
166504 bytes written at address 0xa1f00000
downloaded 166504 bytes in 6.872053s (23.661 KiB/s)
Who can help me finding out what goes wrong here? Thanks in advance for any help!
Kind regards,
Eric
EricvL
Re: Toonrooter script hangs at reboot
Post by EricvL »
After fiddling around for hours, I discovered the issue is caused by a driver conflict with my LCD display, which is using the same GPIO port.
I created a small script to switch between two config.txt files, one for the ToonRooter and one for the LCD display. Now everything is working OK.
Kind regards,
Eric
Return to “Toon Rooting”
