Still in doubt if I should use HomeSeer or Linux programs like MisterHouse.
I recently aquired a PMI-X35 and I know it works on HomeSeer. Does anybody has experience with PMI-X35 on MisterHouse or Linux software?
thanks!
Xanura PMI-X35 on MisterHouse?
- Snelvuur
- Forum Moderator
- Contact:
you can also try www.domotiga.nl for instance, but every program that support the ctx35/pmix35/ti0203 (ti0203 if i am correct, you have a eu version and us version, different names) then it will work.
Thanks, Erik.
I had a quick look, but I'm not sure if I should go Linux...
Thanks for the reply
- Snelvuur
- Forum Moderator
- Contact:
If you want it clean and simple, go for homeseer.. if you dont mind some more challenges go for linux. Not everything is supported in linux as good as in homeseer, but then again if nobody works with it, it wont get support anyways..
