http://store.homeseer.com/store/Z-Wave- ... 38C57.aspx
<b>Overview</b>
HSM100™ a new HomeSeer Z-Wave® device featuring three-sensors-in-one! HSM100 is primarily intended as a motion sensor but also includes temperature and light level sensors. Use it to control Z-Wave devices directly or trigger HomeSeer automation events for whole house control of Z-Wave and non Z-Wave automation products.
<b>Motion Sensor</b>
The sensitivity of the HSM100 motion sensor is fully adjustable, allowing pet owners to tweak the unit for best performance without false positives. The unit has a range of 30 feet and the sensor angle of view is 90° (horizontal). For best performance, mount the unit flush against a wall at a height of 6-8 feet. It is not necessary to point the unit downward. An exposed side-mounted button allows for easy unit testing and setup and the default setup cycle (10 min's) provides HomeSeer users and installers plenty of time to configure the unit.
* Passive Infrared Sensor (PIR)
* 30 ft Range
* 90° Horizontal Angle Coverage
* Adjustable Sensitivity (for 'pet friendly' operation)
* Programmable Timeout (for 'no motion' detection)
* LED Motion Indicator
<b> Illumination Sensor</b>
The illumination sensor of HSM100 can be programmed to work in tandem with HomeSeer software and controllers to ensure greater lighting accuracy under a wide variety of conditions. Use it to light rooms *before* 'sunset' on cloudy or overcast days. Use it to prevent 'on' commands when sufficient natural light is already available.
* Detects the amount of light in the room
* Lights stay off if there is sufficient natural light
<b>Temperature Sensor</b>
The temperature sensor of HSM100 can be used to adjust heating and cooling systems to keep the room comfortable. Use it also to monitor areas of concern where conventional thermostats are not installed.
* 32° - 104°F (0° - 40°C) Range
* 0.2°F Resolution
<b>Battery Level</b>
In addition to sensing motion, light and temperature, the HSM100 also monitors its own battery condition. Use this feature with HomeSeer to trigger email, phone or text to speech alerts if the battery drops below a certain (user definable) point.
<b>Z-Wave Wireless RF Communication</b>
* Advanced Mesh Network Protocol
* Includes 300 series Z-Wave chip
* 300 ft Range
* 40,000 bits/sec
* Adjustable WakeUp Notification
* Up to 4 Associated Z-Wave Nodes
<b>General</b>
HSM100 is battery powered and needs no wires to operate. HSM100 can be wall mounted or simply placed on any flat surface. Battery lifetime typically exceeds one year but depends on the operating modes programmed.
* Two piece wall mount enclosure or can be placed on a flat surface
* Battery Powered (3 AAA)
* 1 Year Battery Life
P.S. Are these "Z-wave" zig bee modules?
new z-wave multisensor
- Snelvuur
- Forum Moderator
- Contact:
Z-wave is not zigbee.
100 dollar for a pir is a bit too much for me, besides i dont have z-wave
If i lived in u.s.a. i might.
Yes, I'm not saying it's a "good deal" - just spreading the "News".
I guess there are a lot of different (and cheaper) ways to get that info.
