(TIP!) Backup Ubuntu to bootable USB
Forum regarding Linux Software and Home Automation Domotica.
Merdeka
Post by Merdeka »
I think we al know this problem. We have a nice setup running Linux and we decide to upgrade something or install something new.
And we screw up our complete install. Happens to me all the time when I test stuff..
What I do now is just follow the steps on this site: http://www.ubuntugeek.com/creating-cust ... ersys.html
Using Remastersys I make backups to iso files. And when I break something I just burn the iso to an USB-stick using Ubuntu's USB Disk Creator and reinstall from this USB Stick.
I keep my data stored an a second harddisk so my typical ISO is around 1,5GB
Hope this helps anyone out.
Snelvuur
Post by Snelvuur »
Whenever i screw it up i fix it normally ;-) i have never reinstalled a linux machine because i "screwed" it up.. i always went for the "dammit, it has to work without reinstalling approach"
Or you can just install it on vmware, and make snapshots :)
Pieterpaul
Post by Pieterpaul »
Or you can just install it on KVM, and make snapshots [:)]
Or use RAID0 and disconnect one drive when testing and let it rebuild afterwards if things go wong
Noel
Post by Noel »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AshaiRey</i>
<br />Or use RAID0 and disconnect one drive when testing and let it rebuild afterwards if things go wong
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">RAID0?? I think you meant RAID1
raid 0: http://www.raid.com/04_01_00.html
Not a "True" RAID because it is NOT fault-tolerant
The failure of just one drive will result in all data in an array being lost.
raid 1: http://www.raid.com/04_01_01.html
100% redundancy of data means no rebuild is necessary in case of a disk failure, just a copy to the replacement disk
Grumble!!. Why do they make those tiny keyboards or is it just my fat fingers. :0)
Raid-1 (Two disks in mirror on the controller)
Noel
Post by Noel »
The 0 is (are on my keyboard(s) between) the 9 and 0.
The 1 is between the ` and 2.. Your's finger(s) must be really fat :-)
You could check the num-pad. (Yes, you can hardly believe that but modern keyboards have that standard)
The 1 is above the big, double-sized key with 0 on it. :)
Merdeka
Post by Merdeka »
<br />Whenever i screw it up i fix it normally ;-) i have never reinstalled a linux machine because i "screwed" it up.. i always went for the "dammit, it has to work without reinstalling approach"
Yeah, But trying out a new kernels and device support for DisplayLink screwed up my install real fast.
Putting everything back from the ISO I created before I started was a lot quicker.
And my girlfriend isn't always to happy when things break. We use our system to watch TV to, so it's not always convenient to work on it. Now I can just boot from my live ISO and she can watch here soaps again.
Or I just boot the ISO in my laptop and work on things from there.
Return to “Linux Forum”
