Fridge Log
Fridge Log
Pieter on your web page you have a Fridge Log, I have a wireless sensor in my fridge that I use for status with doomotion and WGL W800, how do you create the log and the bars graphics.
Fridge Log
Here is a Homeseer script for logging Devices, just add it to the device. The driver in this case is for a MYSQL database, which can be downloaded for free. If you are using MSAccess you only have to change the driver. I would recommend MYSQL instead of MSAccess because Access is rubbish specially when connecting your database to the web and use it also for updates from within Homeseer or other applications (miltiuser part)
In this topic you can find info on how to make charts etc.
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=65
<h4>Homeseer Script</h4>Dim my_conn, strSql, rsp, code, last_change, device_status, last_change_oud
Sub Main()
Set my_conn = createobject("ADODB.Connection")
my_conn.open = "DRIVER={MySQL ODBC 3.51 Driver};SERVER=localhost;DATABASE=NAME-DATABASE;UID=XXXXX;PWD=XXXXX;OPTION=35;"
Set rsp = CreateObject("ADODB.Recordset")
StrSql = "SELECT * From Fridge"
rsp.Open strSQL, my_conn, 1, 3
code = hs.GetDeviceCode("Kitchen Fridge")
last_change = hs.DeviceLastChange(code)
device_status = hs.DeviceStatus(code)
If device_status = "3" then
device_status = "On"
End If
If device_status = "2" then
device_status = "Off"
End If
rsp.AddNew
rsp.Fields("Device").Value = "Fridge"
rsp.Fields("Datum").Value = Date
rsp.Fields("Tijd").Value = Time
rsp.Fields("Device_change").Value = last_change
rsp.Fields("Status").Value = Device_status
rsp.Update
rsp.Close
set rsp = nothing
my_conn.close
set my_conn = nothing
End Sub
Pieter Knuvers
Sub Main()
End If
End If
rsp.AddNew
rsp.Update
rsp.Close
set rsp = nothing
my_conn.close
End Sub
Pieter Knuvers
Fridge Log
BWired (Peter),
I don't know if this is the right place and the right conclusion but i give it a try.
If the HomeSeer scripting language supports the "else" or "else if" statement then i would suggest that you can make a little evaluation improvement, wich can 'speedup' something. Oke this is a verry (read: verrrrrrrrrrrrry) small point of improvent, but all small pieces will help
right?
<br />If device_status = "3" then
End If
End If
End If
End If
Fridge Log
yes you are wright
they all work!
The database insert can be much inproved as well with a simple insert statement
Fridge Log
ok, i will try this script and let you now
