One of the circuits I try to switch in my house is made up of 6 Hi power Leds of 1W each. I can switch these lights on with a X10 module but cannot switch them off. Only with the manual switch (black wire to L) I can switch them off. It is not problem with not enough minimal load, I replaced one of the Leds with a 50 W halogen bulb and the problems remains. Any ideas ?
Thanks for your help !
Tony
X10 does not switch off
- Advanced Member
- Contact:
Perhaps the LED power supply is producing some kind of interference with X10 in on-state. Did you try to move it closer to your computer interface? Did you try to disconnect a couple of LEDs to reduce the load on the power supply (and hence reduce the interference it may produce)?
@Mindbender ... Good idea !!! I can start off with only the halogen bulb and then one by one add Leds .. see what this gives me !! Thanks !!!! Will keep you posted !
Tony
Tony
@Mindbender again ... Hi, I tried your suggestion ... as soon as there is 1 Hi power Led in the circuit .. it fails ... Replacing all the Hi Power Leds by 50 W / 220 V halogen bulbs solves the problem ... So .. do you think placing a filter in the circuit would solve the problem ?
Thanks for your help !!!
- Advanced Member
- Contact:
Sorry dude; I'm not very active in the forum these days, so response can take a little longer...
We need to figure out the source of the interference first. You write you're using 220V halogen bulbs; This suggests that replacing the LEDs actually means "replacing the LEDs and their power supply", right? I was under the impression you were using a 12V power supply, 12V halogen bulbs or 12V LEDs.
With this new information, it is fairly safe to assume the power supply for the LEDs is causing the interference. Is the power supply integrated in the LEDs? If not, you could try to connect only the power supply to verify this.
This is a three-wire (neutral-connected) on-off appliance X10 switch?
Two-wire X10 modules pick up their X10 signal <i>through</i> the load and if the load doesn't conduct when it's off/on, the module can't turn on/off.
Steve
Steve
Hi! I've experienced the same problem on 12V halogen lamps in my apartment. In one of the situation I've replaced the 12V lamps for 230V lamps and took out the electronic transformer that was sending noise to the X10 network. In the other situation the transformers were not easily accessible so I put a filter micromodule after the LW10 and also worked out.
s4813M - http://www.eurox10.com/Product/Micromod ... S4813M.htm
Hi,thanks for the replies ! Could you please let me know exactly how you wired the FD10 ?
Many THanks !!!!
Many THanks !!!!
That is correct ! The load being the 230V 1W Led bulbs .. But even if I replace one of these with a normal halogen buble, the problem remains ...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by stevexyz</i>
<br />This is a three-wire (neutral-connected) on-off appliance X10 switch?
Steve
Steve
Many THanks !!!!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by TOKN</i>
<br />Hi,thanks for the replies ! Could you please let me know exactly how you wired the FD10 ?
Many THanks !!!!
Many THanks !!!!
Many THanks !!!!
