Version 0.6.1.2
Moderator: RdP
Re: Version 0.6.1.2
Robert,
My conf.:
HomeSeer (Pro) version is: 2.3.0.129
FRITZ!Box Fon WLAN 7270 version is: 54.04.76
Fritz!plugin version is: 0.6.1.2
I don't have interop.adodb.dll and cannot find it easely on the net, so can you provide it as prommised bij version 0.6.1.1?
About the phonebook what isn't loading; maybee there is something wrong with the password authentification, i get a log in the Fritz!:
31.01.10 15:19:31 Login to the FRITZ!Box user interface from the IP address 192.168.178.23 failed (incorrect password).
I found this with testing the WLAN device in HS, and isn't working as wel.
Grtz,
Arjo.
Without password in the Fritz! The WLAN device and the phone book are working!
My conf.:
Grtz,
Arjo.
Re: Version 0.6.1.2
You are right; that's the big change...Rebel wrote:Without password in the Fritz! The WLAN device and the phone book are working!
More about this later this evening!
Re: Version 0.6.1.2
Here's a version that can provide me with some input:
http://www.hekkers.net/files/FBF_0612a.rar
Only the HSPI_FBF.dll has changed, regarding logging; nothing else!
This download also contains the Interop.ADODB.dll.
If you install this version and want to help me, turn on debugmode and try to refresh the phonebook and turn WLAN on.
Then mail me the logfile, your fw version and if you had a password on the fritz. That should provide me with enough information.
My email address: fritz aapje hekkers punt net
Re: Version 0.6.1.2
Wow there's something that changed, now the phonebook is working on the FBF config page. It won't display on the HS status screen.Digit wrote:Here's a version that can provide me with some input:
To turn on/off the lan gives a (large)error, but in the logfile all my voip settings and numbers are given. Something to do about that?
I'll try to get out the private information and send you the logfile.
Re: Version 0.6.1.2
Strange.. i only added some log entries.
No Phonebook display on HS status screen? that is not a bug.
Large error? Where do you see it? Can i get a screendump?
Or do you mean inside the log? Can i see that? Don't be mistaken by the HTML/Javascript output you see.
No, there's nothing to do about logging sensitive data. It is all embedded in html for example.
Turn off debugmode and hope someone else sends me his logfile.
Re: Version 0.6.1.2
Robert,
Did you found any solution for supporting fimrware 58.04.78 ?
Re: Version 0.6.1.2
An upcoming version has been tested with the following (thanks to Rebel, great!):
FW version : 54.04.76
Soon available at your local Plugin provider
Re: Version 0.6.1.2
Enver,
I have asked for people who have problems to turn on debugmode and send me log files.
I ask you to do the same.
Re: Version 0.6.1.2
Robert,
I will do that asap..and send the log file..
thanks
thanks
Re: Version 0.6.1.2
First of all thanks for this terrific plugin (using 0.6.1.3).
Yesterday I integrated the phone information into HStouch and it works quite well.
The only problem that I face is that when I like to change the information that is shown (for instance to: %CSD %CST %D %N %TM) then Homeseer still comes up with the original setup (after saving). Is there something I can try to resolve this issue?
Re: Version 0.6.1.2
I think not.. ehh, yes there is: have a little more patience for a few days, version 0.6.3.1 is coming out soon.
I can't reproduce this anymore with the version I'm currently using/testing, so you can consider it solved.
Re: Version 0.6.1.2
After two days running I came home and discovered that the format is now exactly the way I wanted it to be. We really enjoy the plugin (even increased the WAF)... Thanks Digit for this terrific plugin!
