electric motor problem ...
Henk
Post by Henk »
My waterpump (230V AC) is not running anymore - by turning it on the motor will turn just 10-20degree and stop with some humming sound ...
i tested the capacitor 12microFarad with an analog Ohm meter - resistance is zero - the needle should show a different behavior ... likely this will be the problem and have to replace this condensator ....
or anything else ??
Henk
Fantic
Re: electric motor problem ...
Post by Fantic »
Your assumption sounds very correct, test it by when applying power give it a swing (start it manually) if you can get to the axel.
Regards, Maarten.
What kind of pump is this?
Could also be a problem id the pump is nor running regular.
I have sometimes the same problem with my Floor heating pump (oxidation), then I use a small hammer to give the pump a small go with a pat on the head :)
Now I have an event that runs the pump every now and then.
Could this be your problem also....perhaps?
Tiz
Post by Tiz »
off topic..http://www.youtube.com/watch?v=7SCt8JPAkgU
Sorry, heb te lang gewerkt en ben melig aan het worden....
Mathijs
Edwin2008
Post by Edwin2008 »
for floorheating it is best practice to run motor regulary to avoid accumulation of dirt, and clocking (verstopping), in the pipes.
** edwin **
wwolkers
Post by wwolkers »
I had the same problem with my Compressor. First suspect was the Condensator, but it turned out to be a wire which got loose.
Replaced all the wiring (special heat resistent wire) and works like a charm again.
Tiz wrote:off topic..http://www.youtube.com/watch?v=7SCt8JPAkgU
LOL :D
Henk
Post by Henk »
Indeed it was a faulty capacitor - so replacing it and the pump is working it can be easy testing with an analog AVO meter ..... using it as an Ohm meter the needle will swing to low resistance and then comes back to high value .....
Henk
