I want to buy an RFXcom, but I don't no which type, can some one give me advice?
I have sensors from Marmitek, (Door sensors and motion sensors), I want to control "klikaanklikuit".
I playing now with Housebot, I am thinking to buy that software.
Regards, Jacco
Which RfxCom
Moderator: b_weijenberg
Re: Which RfxCom
Check the RFXCOM forum for topics like this, you will find lots of info.
http://www.domoticaforum.eu/viewtopic.php?f=27&t=4349
- b_weijenberg
- Forum Moderator
Re: Which RfxCom
The 433.92MHz receiver and standard transmitter can be used in HouseBot for KAKU and Marmitek.
USB:
USB 433.92MHz receiver http://www.rfxcom.com/receivers.htm#80002
Add an optional 868.95MHz Visonic receiver. http://www.rfxcom.com/receivers.htm#40079
USB 433.92MHz Transmitter http://www.rfxcom.com/transmitters.htm#80005
Ethernet receiver+transmitter:
433.92MHz receiver http://www.rfxcom.com/receivers.htm#80002 and select a 2 port LAN 83003
Add the transmitter http://www.rfxcom.com/transmitters.htm#70031
USB:
- Starting Member
Re: Which RfxCom
So if I buy this
I want USB
I can receive the sensors from my marmitek system and I can control the klikaanklikuit units?
Is this correct?
I want USB
Is this correct?
- b_weijenberg
- Forum Moderator
Re: Which RfxCom
No, not correct!
An USB interface can have (1 or 2 receivers) OR 1 transmitter.
So if you want the USB version:
- Starting Member
Re: Which RfxCom
Could anyone explain the difference between the USB and the Ethernet version? Can the Ethernet version function stand-alone, without the "server" running all of the time?
Gert
Gert
- b_weijenberg
- Forum Moderator
Re: Which RfxCom
The USB and LAN are almost functional identical. For a home automation environment, both need a (low-power) system running 24/7 to process the received data or to transmit commands. No buffering is done in the interfaces.
There is an iPhone and an Android solution that uses the LAN interface without a system running:
http://www.homeautom8.com/iAutomate/
http://dehuysser.appspot.com/android-apps/jmom-ng
